The ZKE module controls power window, central lock, boot release and sun roof. On worst case scenario, all freezes!! Must use physical key. From inside, only driver's door can open.
There's a write up here:
http://www.bmwgm5.com/ [Interestingly, our club was mentioned in the website!!
Back to the question, if ZKE module complete failure:
1. Only driver's door can open from the inside, and use physical key from outside.
2. Yes. Other doors no key hole and lock won't release from inside.
3. Yes.
In Rachel's case. The ZKE didn't fail. Only her driver's door central lock fail. That's why she can still use her remote to open her boot.
Apart from the "problematic" ZKE module, the E90 driver's door lock is a another common problem. It first burn fuse. SC will replace with a bigger rating fuse, failing which, they will replace the lock. My fuse was replaced. So far so good. Keeping my finger crossed. I wonder if there's any E90 owner here doesn't experience central lock problem before?!
