Drivers door won't unlock with remote
viperjet
My drivers door will not unlock when using the remote or the central lock/unlock button. When I lock the doors with the remote they all lock correctly, but when I try to unlock them they all unlock except the drivers door. I am able to unlock the door by pulling the door handle from the inside but its pain to do so every time I lock my doors. If you guys have any advise on what it might be, I would greatly appreciate it.Thanks for the help,E90 320I 2005 sedan
E90s has 5 fuses thats responsible for the central locking system & remote unlocking. Maybe you have a blown fuse. If after replacing the fuse it still doesn't work, then its the actuators problem. E90s fuse box is located behind the passenger glove box.
Fuse 2 and 19 Empty... 56 and 57 good... 63 cannot remove...
Workshop diagnosed and confirmed the Drivers Door Lock Actuator P/N: 51217202143 Failures.
Door Lock Actuator replaced. Everything back to normal again !!!
Yup, same problem except mine was passenger door. Same solution too :)
Same prob..when to my SC, immediately they told me this & that, change this & that.. when I f**k them..and told them no bullshit please, I've been with this SC for quit sometime now.. Then they say it is because of a fuse.. total cost "Free"
