DIY angel eye for e36
i think i got it at some shop at sg wang (IT Center).. i asked every shop and the price just went down and down after I told them of the 'other' shops' price. It took a while though.
Originally posted by ZeNeGeR@May 19 2005, 04:08 PM
wah ? r u guys putting that fan to ur car eye ?? some more can cool off ur head lamp
more airflow and cooler makes more hp......... :D
another mini-supercharger in the making.....
unker j,
how about the voltage converter, any difference in volts for the ccfl ? i know some pc acc uses 5V, if then, need to get a step-down transformer..... :(
God! That is one brilliant idea. But does anyone knows about the headlights diameter? Will it fit all around the headlights?
headlamp diameter is about 100 to 105 mm.
Check out WRC at Bandar Sunway. The price of a Taiwan angle lamps almost comes to a German Hella. How they sell? :getyourfactsright:
mike where is the angel eye that it selling for RM380?
can give location to the shop?
maybe mine is not CCFL. I have no clue but it has a blue ring. it's a noisy fan too. grrr.
If your is ccfl type, then it should come with a inverter. The inverter look like a long rectangular box about the half the size of a ciggie box. If your is connected straight to the 12V supply connector of the computer then it should be LED.
then it is LED then, coz it comes straight from the power supply. Sorry folks if I terpotong stim.. :p
grovees are not evenly spaced out. Since this is your first rim, I think you can improved with the others.
BTW, good try !!!. Way to go.. When you are going for mass production? :D
its quite a uphill task to get this result , but now know how to do fast and perfect . very hard to explain in writing . call me 0122290635, i tell you all
zeneger:my advise is you do it your self when i tell you how to do it then you know why......
vincent, heard that you cut the groves manually by hand using a thin saw.. hey this will take forever. Suugest that you use an electric drill machine (for engraving). I have one that I bought when I first started on the diy. I need to find it and loan to you if you like. I have make my own blade using the top of a milk can as I could not find the right blade as they were too thick.
just a word of caution, you need to practice a bit on another rod to get the feel of the cutting to get it right. Practice make perfect..
now where is my drill... :dunno: :dunno:
