Hella Angel Eye
:D You da man :yahoo:
Looks like its gonna be a success afterall.... :yes!: :nyehehe:
Hey... you are not working today meh? Anyway, whats taking you so long.. quickly put that ciggy out and get back to work.. wanna see the angle-eyed E30 light this Thursday liao.. :yahoo:
Jarance, you are the man. Pls give some comment on the reflective portion after using the hot gun. Does it maintain as original or would it bubling or burned. I had seen a BMW reflector that was burned cause the owner using a bulb that are almost double wattage than the recomended one.
p/s: pls do mine once you master doing it. he..he..
Oh problem... The high beam head lamp casing is made of metal but the low beam headlamp is made of plastic.
Try to heat the low beam head lamp just now after a break. The silicon and casing are melting at the same time. :cry: :cry:
aiyaa.. back to square one again... need to experiment again.. One lowbeam headlamp already toasted. i mean really toasted... arr..gggh....
jam and butter anyone?
strider, the reflector is intact for the high beam after the glass cover is removed..
bro don't be like that lah.. good thing come to those who wait..
having problem removing the glass cover for the low beam cos tthe casing is made of plastic. :cry:
well try again after having about 20 ciggies... :wink: :wink:
Hahaha...good effort there, don't forget I passed you a low beam headlight long before...OOOPPSSS hope that's not the ONE that was melted :cry: :cry: :beaten: :blink: :blink: :( :blink: :blush:
albundy, your one still in the virgin stage.
the toasted one belong to mtek. he have given me the permission to "toast" it.
if R&D is successful, you will be first to know.. ha..ha.. being putting the project on the shelf until kena racun by the young one in klang TT. :D
OK Tonight at Bukit Jelutong from 8:30 p.m.. Phase II of E30/E34 headlamp - brain stroming. come take a look. Need all the help..
Jarance,
Did you manage to open the one with the plastic casing? :ph34r:
Jarance, I can definitely live with high beam "angel" eyes :D :D Something is better than nothing. SO when can I pass you the headlights my Lord :nyehehe: :nyehehe: :nyehehe: :) ?
yes master. tonight at bukit jelutong can kah?
what about the ccfl angel eye? I heard now very cheap. cost about rm310 or something around that price. you can share the cost with somebody if only 2 angel eyes is used. I don't mind sharing the cost cos i also want a pair only for my the other eyes.
Now... the heat gun only works on metal casing. Got to find another way for plastic casing, huh?
Have you tried 2 ton glue? I did use it to glue the lose cap at the back
of the casing so far so good holds well trial and error make it perfect sifu J.
looking foward to see the result and janji got light at the high beam let it be anything.
good luck :yes:
Originally posted by willie@Apr 28 2005, 07:27 PM
jarance u sure that CCFL is only 310?
yup, that what Mikeong says. I have make appointment to check it out but he did not response. Will try again. Calling Mike, where are you? :dunno: :dunno:
Originally posted by willie@May 2 2005, 07:50 AM
eh, if really 310, i want also leh :)
willie,
I will check it this weekend with mike if he is available. Will let you know of outcome.
:cry: nearly forgoten this tread is sleeping oledi kah? what happen next no news Jarance! looking forward for the step how to hold the angels in the casing for high beam side.
