Cooling system parts replacement for E46 330CI
koreng
Dear legends,May i know what are the costs associated with cooling system replacement? As mine car is about to embark 120,000 km soon. Would like to look into the cooling system replacement as a preventive maintenance.Parts list are as per below:-Cabin filterSerpentine beltsCoolant flushCoolant hosesTiming oil seal RM 90.00?Expention tank RM 450.00? Can get cheaper?Bottom hose RM 185.00Bottom hose switch 120.00Upper hose RM 276.00Radiator by pass hose RM 410.00Thernostat bottom RM 249.00Water Pump - 1 pcs 195.00?Belt tensioner bearing - 3 pcs RM255.00?Water pump pulley?Water pump pulley bolts?Alternator Deflector Pulley?AC Tensioner pulley?Alternator belt?AC Belt?Please advise me to exclude out unnecessary parts from above list? Thanks you. As i need to have contingency sum if anything. Thank you in advance.
The Serpentine belt drive the water pump, power steering pump and alternator all at the same time.
service your radiator and change the side tanks. if not sure about the health, then change new. also newclip for the hoses, radiator rubber mounts. and got chance the crank pully oilseal at the engine side if not leaking. tensioner pulley's all no need. change the belts yes. while u are there do a flush for the power steering oil.
What would you u do for cooling system preventive maintenance at 120,000 Km?
Is Expansion tank replacement necessary?
THANK YOU GUYS. Appreciate your help !
yes, if you are the person which is going to overhaul the the whole cooling system, might as well. you see, the whole cooling system pressure is equal at all points, so doing all n leaving the expansion tank, it will be on a 'first' thing to go..if not over a short period.
I rather have the peace of mind for the next 3 years.
