BMW E36 Programming, Security, Parts and Performance Parts IMPORT!!
JOKER
Banned
These upgrade parts for e36 328i based on my experiance :rock: and may fit onE46, E36 M3, E36 325i, E36 318i and E36 320i. :burnout: Anybody interested, give feedback!!, i will ship it to you!!! :listen: Note: All parts depend on avaliable and duration between 1 to 3 weeks. Price may change (cheaper than listed) on number of parts order, shipping and number of customer order the same parts. FRONT STRUT TOWER BAR ---------------------- RM 350 :top: 92-98 BMW E36 6-cylinder STAINLESS STEEL EXHAUST HEADER ---------------------- RM 850 :top: 92-98 BMW E36 6-cylinderADJUSTABLE COIL OVER SPRINGS ----------------------- RM 45092-98 BMW E36 ALLFlex Disc (Guibo) -------------------------------------------- RM 350 E36 328i, E36 M3, E46 M3, MZ3Front Door Lock Actuator ------------------------------------- RM 350E36 AllRear Door Lock Actuator -------------------------------------- RM 350E36 AllBall Joint; Lower Left/Right ----------------------------------- RM 400 92-98 BMW E36 ALLThis is the upgraded all metal version from Meyle designed to remedy the premature failure problem with E36 chassis ball joints. M50/M52 Aluminum Thermostat Housing ------------------ RM 200 :top: 92-98 BMW E36 6-cylinderA COMMON FAILURE ! Replace your brittle plastic factory housing with this rugged aluminum one! Includes profile gasket.Steward High Performance Water Pump ----------------- RM 1100 :rock: 92-98 BMW M50/52/54 and S50/52 6-cylinder engineThis high performance water pump is a direct replacement pump designed to fit a wide range of BMW engines with no modifications. That includes accepting the Factory Fan Clutch. The front of the BMW High Performance Water Pump is stock appearing giving it that classic BMW look while the back is all business. Features up to 20% increase of water flow over stock pump, and it TWICE as efficient as factory pump, much less parasitic drag than other pumps, stainless steel impeller, heavy duty bearing, high quality water seal. THIS PUMP COMES WITH A LIMITED LIFETIME WARRANTY Fuel Pump Upgrade ------------------------------------------- RM1600 :rock: later production 1995 M3 & 325i, all 1996-1999 M3, all 1996-1998 328i, all 1996-1999 328is, and all 1998-1999 323islater built E36 cars are much more prone to fuel starvation then the cars manufactured before January, 1995. This is caused by a less efficient siphon pick up tube in the driver’s side sending unit. During hard cornering this will cause the car to temporarily run out of fuel which can cause engine damage or cause the car to become unsettled at an inopportune time. With the later fuel pump sending units you can start having fuel starvation as early as 3/8 of a tank of gas where with the earlier sending units this condition does not start to occur until below ¼ tank. This kit is a great inexpensive way to get more fuel out of your tank. For endurance racing there are other more expensive ways to get all the fuel out of your tank, but for driver schools or sprint races this is the way to go. aFe Cold Air Intake Kit ----------------------------------------- RM 1400 :rock: E36 All 6-cylinderPower Pulley Kit ---------------------------------------------- RM 1200 :burnout: E36 325i 323i 328i M3 M Coupe/RoadsterDesigned them to underdrive the water pump, power steering pump and alternator*. Adding these is like getting FREE HORSEPOWER - there are no downsides and underdriving each of these accessories has been proven safe through years of on and off-track use. These kits provide a 10%-20% overall reduction in driving your car's systems.Kit includes water pump, power steering, alternator pulleys and belt. The T-6061 hard anodized aluminum pulleys account for a 10 to 20-percent decrease in accessory speeds, reducing the load on the engine but still maintaining a safe margin for reliability on all components. OBD2 DME/ECU programmer ------------------------------------------- RM 1200 :top: 20 pin or DLC to PC USB interfaceSCYTEK VisionGuard 8000 alarm system ----------------------------- RM 1800 :top: Full Color Camera with Night VisionAutomatic picture capture upon security violationSelective picture capture through the remoteStore and recall up to ten discrete images on the LCD remote.One Carbon Fiber 2-Way True Color Picture remote control.One Carbon Fiber Slick 5-Button Remote With Super Bright Blue LEDBuilt-In Parking-Light Relay Programmable (+/-)One 5 button code hopping remote control Sleek Carbon Fiber with Super Bright Blue LEDPlug In LED and Override SwitchRemote Start Tachless Mode using Adaptive Digital Signal Processing -compatible with all vehiclesRemote Start Tach MonitorStarter Interrupt OutputDual stage Electronic Impact sensorPower door lock controlTrunk ReleaseParking Light Flasher programmable polarityCourtesy Light ControlAnti-grind OptionGas or Diesel compatibilityCold Start timerSelectable Engine Run TimeTurbo Timer (adjustable)Smart Network PortEasy programming Via your PC, Pocket PC or Valet sw. and Remote TransmitterLifetime Warranty
