astroboy
Well-Known Member
- Dec 15, 2006
- 8,734
- 63
Schwepps;445051 said:Leaving a nail or screw in your tyre raises the risk of irrepairably damaging the plies and cords. I think that's what happened to me - the screw or whatever worked into a 2cm wide gash on the inside, until it popped out. On the outside it was quite a normal hole. And it was only 6 days from my last Sunday morning pressure check. The tyre was a goner.
I don't think AAM can help in times of full deflation because you don't have a spare tyre to begin with. This will be the time when you will curse and swear why BMW has to pick RFT. Even the jack mount under our car is not helping because normal jack will crush the plastic support on the jack mount.
When I say leaving the nail stuck on the tyre is not meant as permanent solution or intentional. Not all object will damage the internal steel belt and of course, you may not be as lucky every time. Damage to the steel belt on the tyre rolling surface will result in "pregnancy" on the rolling surface and cause your wheel to vibrate. Only experience this once in my 20 years driving experience.. sorry not since WWII..
What I'm trying to say is you normally won't suffer immediate full deflation on conventional tubeless tyre. You can identify those deflation through frequent visual inspection or during refill. Once you notice u suffering losing pressure to one of the wheel, go straight to the tyre shop for inspection, rather than look for the nail and unplug it at the petrol kiosk, or dumber still, unplug it at the R&R on the highway in the middle of the night, with family members of old and young in the car, .. and ask yourself "What now?" when witnessing the air gushing out..
You didn't suggest Rachel to get the mobility kit? :wink:
