Centrafuse + ibus controller
skinhead
Im managed to use my steering wheel buttons to control volume up-down, track selection etc using centrafuse. the ibus interface is a chepo one in the ebay tht i bought. Not resler. the software i use to interpret the steeringwheel key press is ibuscomm. it will broadcast the equivalent keypress to centrafuse for controls. so if ur using centrafuse as the incar entertainment interface, ur steering wheel buttons is still functional. u need to map the proper hotkeys in centrafuse and assign it to ibuscomm. a huge move forward for my incar pc proj :top:
skinhead, good to know this, thanks for the information!
Now when can we see some sneak peek of your project.. :pcguru:
yea aidil, soon i will be installing it on my e39 once i finish fabricate the bezel. for now its just mere testing all the sowftware+hardware and its compatibility on my old laptop. for now most of the hardware like the 7" touchscreen monitor, usb gps, reverse camera, ibus interface etc are working very fine with the intended software & driver.
fyi, ive tested and confirm tht i can control the steering wheel buttons ( vol up,down, seek forward etc ..) in the window environment. means tht if ur runnning ur win media player, u can also control ur volume up0down etc from ur steering wheel...fantastic...
Good to hear good feedback for ibuscomm, do you mind giving a link to where you downloaded it?
Bezel is an important part of the project because you hide everything else away. Janus's bezel are sensibly priced I think
aidil, it can be download from here . u must make sure u have microsoft .net framework 2.0 sp2 minimum installed for it to work on ur pc.
i dont think for euro 100++ t]its sensibly pricey la... im gonna diy. and post pic here later... :wink: wish me luck
Thanks for the link.
The raw one is 59eur, just need painting
Just tested the link, this is for ibus communicator not ibuscomm. I used this one and not very stable for me. Need to check my system again if this is working fine for you..
do you hv fac cd changer ? remove the ibus connector to it n run the s/w again.
I don't think the CD changer is connected since I used to have DICE silverline pro connected there. Does the software continue to work after the pc is brought up from hibernation?
yup.....
Skinhead, can you post you're ibuscomm.ini file? My setup ibus and centrafuse is not working
thanks
