car refused to start :(
cg
This morning my car refused to start with all sort of error messages. from restraints system, abs, traction, gearbox and etc... in the last message it show a battery symbol on the dashboard. i only use the car during weekend. sometimes once every two weeks. wondering if that kills the battery.
Anyone have use a battery charger? Was thinking buying a Bosch C3 battery charger to top up the charge since I seldom use the car....
Any advice from sifus ??
BTW, the remote trunk cannot open from the remote or inside compartment button. Need to use key to unlock it.
Hi cg, I got this from another forum;
But the main cause for short battery life is the battery sitting at less than a full charge, which leads to cell plate sulfation. Very short term sulfation is reversible when the battery reaches a full charge again, and even medium sulfation is reversible through a designed period of overcharging while controlling temperature, but if the battery sits on a short charge for extended periods the crystalline formation on plates permanently hardens and forever blocks future charging.
And other than a malfunctioning alternator or voltage regulator, or a parasitic drain from a malfunctioning power consumer in the car, a low battery charge is almost always the result of driving habits. BMWs use a huge amount of power, and a seldom used car, a car that experiences multiple short trips or a car that is driven slowly in stop and go traffic will not fully charge the battery. And the ECM in conjunction with the alternator can only work within the limits of engine speed and ambient temperature to optimize charging (excessive battery temperature when charging at high voltages causes water in the acid solution to be boiled away).
Batteries are not that expensive and whether you get two, three, five or seven years of life there is not a huge difference in annualized cost. For most people the annoyance of being stranded is a far bigger issue. By occasionally measuring your battery voltage after the car has gone to sleep (using a $5 multimeter) you will know if you are undercharging the battery and can expect a shortened battery life.
If driving habits lead to an undercharged battery, the best solution is a battery tender, which keeps the battery fully charged and prevents sulfation, but generally requires private garaging of the car. If you cannot conveniently use a battery tender, then after two years have your battery tested for free at an auto store every six months to get an early warning of impending failure and replace it before you are stranded.
you can jumpstart the car (although there is a slight risk). a better option is using a battery pack to jumpstart it. I heard that even if you connect it wrongly it will not damage the ecu/electronics.
I usually follow the following procedure to jumpstart:-
1)REMOVE THE KEY FROM THE IGNITION!!!!!!!!!!!!!
2)Make sure the steering wheel is straight (this is to ensure that the active steering error doesn't appear)
3)Connect the jumpstart cables properly
4)Turn on the car with the good battery
5)Leave it running for about a minute (let the electronics initialize)
6)Turn the car on. Remove the jumpstart cables
If the active steering lights up, you need to turn the steering all the way to the left and back again to the right. restart your car and it should go off.
