agree with cempaka. as d other guy said, we cant c d damage of d sidewall until we open up d tyre n c d small rubber balls inside. so i think d safest way is dont patch rft tyres. but i do recommend patching it due to d price of tyre is expensive
But when patching, please choose to patch from inside. it may cause u sumwhere around rm30+ at lim tayar ttdi, but it is safer coz they need to open up d tyre 1st to patch frm inside. when they open it up, they can clean the small balls inside. n d technicians also can recommend d cust to change d tyre if they c d damage is really2 worst.
or u can c it n judge 4 urself. plus technically, patching from inside is more strongger coz d method used is almost similar to d " tampal tayar motor", which means tht d part they tampal is much larger than d puncture. d plug type is not recommended coz to put in d plug, as been said by astroboy, they force it into d puncture. + when d puncture is too small for d plug, they force open d wound to let d plug into it. n this will more likely b d weak spot for ur tyre. plus, d plug type can be seen clearly at d tyre tread, which also might come out when travelling long distance @ high speeds (ive seen this happen b4).
so d conclusion of all of my babbling here is, if u want 2 patch ur rft tyre, patch it from inside for ur own safety. it may cost u double frm d plug type, but it is safer. :top:
