azam318;382744 said:
Sifus, sorry my silly question, what is ms mode ds mode mean?
Not available for E36 model.. especially for manual gearbox.
Only available for e46 or later model. Basically for auto transmission.
In most convensional auto, you will have "P", "R", "D", "L2" and "L1" (sometime L3 if your gearbox have more gear ratio). As for E36 auto, you can press a "S" button which will make the car more revey.
For E46 and above, the gear shift is the same as auto shift except that when in "D" mode, there is slot which will allow you to shift the stick to the left for semi-auto mode driving. Once it is in this slot, there is a "+" and "-" sign. By pushing up, you will shift the gear down (eg. M3 -> M2) and pulling down, you will the gear up one step (M3 -> M4). Basically the feeling is just like a kupchai. One down and 3 ups if you know what I means. :wink:
The gearbox control is intelligent enough to overight your manual control sometime. Say you shift the gear to M5 and you happen to slowdown, it will automatically shift it down for you when you forget to do it.
Yes, shifting from MS to DS to MS to DS is a brezee. I was sceptical at first but after a few attempts at various speeds, I managed to have the confident. Most of the time on straight road, didnt bother to change to manual mode cos the pickup is good enough to overtake safely on auto mode. :top:
