520d n47 common problem.
Tangkilo
New Member
CKD AND CBU different?
I am looking to purchase a 520d but not sure the different between the different of local CKD and imported cbu
Quick look at the internet suggest that the 2l diesel engine of bmw, n47, has quite popular problem of timing chain problem.
And it's difficult to change because need to dismantle the gearbox/transmission
It's common to happen to have timing chain failure?
How much does it cost to have egr + swirl flap delete?
Does it have cat exhaust or just muffler only?
If remove cat/dpf, require to remap? How much it costs?
And cost to change timing belt before breakdown.
What about its 8 speed transmission? Reliable?
Single and twin turbo, got twin turbo failure?
And the maintenance cost, can the engine runs on semi synthetic engine oil?
Another alternative is e300 mercedes hybrid diesel. Can the hybrid convert to normal aircon pump?
A : I have not seen a CBU (recond) unit.
A : If you do find a CBU unit, then you better make sure it has more specs loaded into the car. F10 520d in overseas are fitted with DPF. Local model does not have DPF.
A : Timing chain problem has not been seen with any local models. It has been seen with the local petrol versions though. I recommend that you go for an end 2013 and above which is a LCI unit.
A : Answered above. Amongst my F10 group, no timing chain issues reported. Only seen on 2 units of petrol versions.
A : Cheap can be done during remap.
A : not sure to answer this part.
A : Yes, remap is about 1.5 to 1.8K depending on tuners. Aggressive tunes will make the car smoky.
A : For diesel, none has changed.
A : Its the best in the business as long its maintained well with oil changed every 100k km.
A : Never heard of twin turbo failure on a diesel yet.
A : I am still servicing with BMW Oil others have used Millers and others.
A : Are you mad? the battery is RM120k to replace. Cannot convert.
wanted to add on, amongst all the F10 models, the F10 520d are the least problematic of the lots. They are generally quite reliable. No regrets with my unit. Would go for G30 530d if it comes in. bored with 520d already.
Even though mine's not a diesel.... hv to agree with this. Mileage per full tank is a dream for its petrol cousin. Bro, dont forget the F10 535d..... hehehehe
bro am looking at a 530d. F10. Pre lci. What’s your view bro?
If u can find an F07 530d, suggest u to grab it soonest bro. Dont think theres any F10 530d around, except for the F07 530d GT. Exceptional savings. Smile when u fill up once every 2 weeks!!
my friend does import of cars from UK. He might be able to help you get a 530d F10 if its available. He arranges everything from shipments, taxes, importation, registration etc.
