Gerald 5;376918 said:Thank you wc9922 & turbology, it is such an excellent info for many. I am no techko but would like to know 1 thing for sure.
Should I use V-Power assuming cost is never a factor?? Thanks
M54B30
M40B18
wc9922;376876 said:Gasoline specs are very complex/secret also as the composition (% by volume) of gasoline are consist of many HC compounds such as oxygenates, paraffins, reformate, isomerates, aromatics, olefins and benzenes.These does not includes the additives. U change something u change the RON and MON as well as other thinngs like vapor pressure etc.
wc9922;376972 said:I think you will find your 530i will respond to V-power better due to it's ECU's capabilities to adapt to fuel quality.
B33mEr;377007 said:Excellent thread this is :top: .... bro schwepps looking back at you history of FC that you have recorded thus far... can you say the extra 0.45sen/l is worth the extra spendin due to the extra km's you have gain by using v-power???
turbology;376748 said:I dont' see how V-power being "the best" since Octane rating is the same.
For 0.45 more, I will just mix myself
Schwepps;376995 said:Since you supply refineries, maybe you can shed some light on the refining dynamics here. The Shell we get is from Shell PD and Bukom. Does Shell also off-take from Petronas Melaka 1 & 11 via the pipeline? I know that Esso is mainly in production activities here, so who refines for Esso, Mobil, Caltex, BHP, etc? How many refineries are there in Malaysia now? Give us a low-down on their relative quality standards (in an oblique way if necessary) As fuels are not all the same, neither are refineries I'm sure. :wink:
wc9922;377034 said:How ECU adapt to fuel quality ?
By checking the AFR target values for each rpm bin that is under closed loop control and adjusting the fuel trim constant for the effective fuel map area so it scales up or down the fuel trim, like a fudge factor. Open loop ecus cannot do this.The VE will be the same for the same (rpm,load) bin but the computed required fuel per injection cycle (ms) will be less. The injector pulse width (ms) will be smaller. Don't mistake this for duty cycle.
turbology;377061 said:Since you can't answer my question directly, and repeating what I already known and point out unrelevant fact, let's pin it down to more specific.
You said V-power is a "higher quality" fuel. Because of what?
(Don't give me VE, AFR, closed loop, duty cycle, injectors pulse excuse)
I agree that MON make a different in performance.
V-power can have higher MON, which make it better "performance fuel".
But, since we can't get any number for MON, we cannot call v-power a "better fuel"
My point is, if any gasoline octang rating is the same, performance wise, any gasoline is the relative the same.
But the the question is, should we pay for the $0.45 different in v-power, which merely the same ??
Some says, V-power give better FC.
Compare $2.45 to $2.00, is 22% more.
Does V-power give you a 22% better FC ?
If I want a better formance from gasoline, I will find something else higher in RON , rather than the "same-RON97-but-no-prove-is-better" v-power.
And Shell claimed "99% of v-power is the same you found in F1". Oh please... all fuel is 99% the same. That is why all of them is call G-a-s-o-l-i-n-e
Cheers![]()
