zhul;576194 said:Nothing can save you from aquaplaning, even F1 cars will slide off. When this happens, just hope that the tyres find their grip again before the car finds the wall.
Hammer278;577607 said:Quick question though, would this mean that a narrower tyre is more suitable for wet roads? I believe less surface area would lead to less chance of water 'carrying' the tyre and making the car aquaplane?
M5POWER;577614 said:I'm not a physician but I think narrower tyres are good for wet surfaces as it will throw out as many water as possible from the contact of the tyre to the road surface. However, the narrower tyres has its own pros and cons too. They are extremely unstable to drive with especially with bigger cars like our 5-Series and such. Taking corners in high speed with those tyres could result in something really, really bad...
If you are used to rallying, if they are having a rally in snow or most wet surfaces they will use a narrower tyres like this:
Afterall, the tyres on our cars are the most optimum like Michelin PS3 etc... The problem with wider F1 car tyres are that they are just too wide. Eventhough they made a lot of threads on it, it is still very difficult to get rid of the waters right here while the car is going around 180km/h..:
Hammer278;577617 said:This is why I asked, are you referring to the wet or dry? In the dry, it's a no brainer however, on wet roads even for our 5ers I believe a narrower tyre is an advantage even through cornering. There is a balancing act of course, I wish there was a site with simple calculation showing the optimum tyre width to have for a car of certain weight in wet conditions. Could be very useful.
M5POWER;577356 said:Actually F1 cars have more tendency to have aquaplaning than our normal road car. It is because of the difference in ride height and weight of our road car...
wider tyre will not give you grip on the wet surface because the main point is to throw out as many water as possible from the contact of the tyre to the road surface.
zhul;577774 said:F1 car on a very wet track is still faster than normal road car on a dry track. You need to remember that F1 cars will change to wet-weather tyres when its raining heavily which will give them more resistance to aquaplaning than the tyres we use under the same condition.
zhul;577774 said:Actual contact area on the road remains the same whether you use wide or narrow tyres. Wider tyres have to work harder during rain because it has to dispel more water from the road to maintain grip. A good wide tyre designed for wet roads will resist aquaplaning better than an ordinary narrow tyre but as you go faster, the tyres cannot remove all water from the road to maintain grip and this may cause aquaplaning.
Exactly, its ridiculous. I was surprised when you started comparing normal road cars with F1 cars when my actual response to an earlier post was in terms of car technology in general.M5POWER;577778 said:Honestly, comparing an F1 car to our road car is just ridiculous because of the cars different characteristic.
No I did not. You are using different context from what I meant in my post.You proved my point... The wider tyre cannot throw out as many water when you are driving fast and when that happens ...
.. I said earlier ride height and weight really plays some part.
Owkey for those who wants to understand more of aquaplaning, I stumble upon one in the net:
My advice, DO NOT drive fast or more than 120kmh on wet roads... They really can bite you!
