fabianyee
Founding Member
- Nov 25, 2004
- 8,860
- 38
Originally posted by DanPromote+Mar 16 2006, 01:05 PM-->QUOTE (DanPromote @ Mar 16 2006, 01:05 PM)Originally posted by Breakpopin@Mar 16 2006, 11:30 AM
yea I remembered asking u about it that day... since it is a 100% replica the only difference is the material and weight. How does the sensor work? Does it depend on the teeth or the magnetic property? I don't mind being the guiney pig, worse come to worse I can still use back the original pulley if it doesn't work and use the T7 replica as a cup holderOriginally posted by fabianyee@Mar 16 2006, 01:16 PM
[have u considered the fact that there are teeth on the pulley for the crankshaft sensor to pick up. Is aluminum teeth provide the necessary pulse signal? iron and aluminum provides different magnetic property. However, u can always be the guinea big to test that.
To be frank, lightened and underdrive pulleys for the accessories are safer than replacing the crankshaft pulleys.
if you underdrive the phulleys.....Originally posted by Breakpopin@Mar 16 2006, 05:30 PM
Calvin Tan,
AHah thats why i PM-ed u even before i posted this thread!!
So anyway, why cant we underdrive aircond compressor pulleys too?Just curious
If you underdrive your a/c compressor you will be driving with a heater.Originally posted by Breakpopin@Mar 16 2006, 05:30 PM
Calvin Tan,
Breakpopin is asking for the underdrive pulleys means power steering, water pump and perhaps an alternator pulley if you want.
Originally posted by Breakpopin@Mar 16 2006, 04:30 AM
Calvin Tan,
Originally posted by E3six+Mar 17 2006, 12:13 AM-->QUOTE (E3six @ Mar 17 2006, 12:13 AM)
Originally posted by fabianyee+Mar 15 2006, 04:41 PM-->QUOTE (fabianyee @ Mar 15 2006, 04:41 PM)Originally posted by The Necessary@Mar 15 2006, 06:47 PM
leforte;341544 said:ess530i
your car being supercharged/modded has nothing to do with the damages caused. your supercharger is just another accessory being driven by the main beltdrive and thats it. there are countless other similarly modded 530s around and non have reported any similar failures. since you mentioned to me your pulley is of a said particular brand, i sudgest you return it for a full refund and bill your damages to them as the manufacturer has a 100% warranty that it would not cause any damages from using it as clearly stated on their website.
IMO your case is a very clear indication or rather a ripple effect of vibration induced stress fatigue caused by the undampened pulley to the attached components. the crank pulley is the one and only component in your drivetrain that generates pulsating vibrations due to the combustion forces of each cylinder per engine cycle. the crank pulley/harmonic balancer is there to absorb/counteract/reduce this vibration pulses from being being transfered to other engine components and accessories by converting any excess vibrations to heat.
FYI since you are reinstalling the original bmw crank pulley, the unit is a major part of the factory balanced rotating assembly, do make sure your mechanic have it properly aligned with the markings indicated on the crankshaft/engine during installation or its just going to cause you another issue later on.
ess530i;341572 said:leforte thanks for enlightening me on this. yes i didn't think the sc should have anything to do with this as the crank pulley is driving the sc pulley not the other way round. but i was told that the stock belt & hoses cannot take the extra initial torque generated by the SC and should be upgraded if possible. then again, many cars have been supercharged to even higher HP without facing these issues. so now the finger points back at the pulley.
i will go for a refund for the pulley + install and would be very happy if i could get 50% of the damages. wont reveal the brand of pulley and where i bought them from yet as this would be quite damaging to its reputation.
anyone with SC + lightweight crankshaft pulleys or just lightweight pulleys in the house...care to share?? do mention if your pulley has the balancing ruber or not...
