under power
bullari
Hi everyone..I've just joint the club and wish someone can just the provide me some possible reasons why my recent acquired e36 318,1997 model seem to be extremely under power. Top speed just merely around 170km/h and the torque (pick-up) is simply to poor where even any small car can easily overdo me.
get your car checked ... usually as for a 4 potter you may reach 190 ~ 200 kmh ...
could be due to your AFM , plugs and many more factors ..
if need power get a 325 or 328 ...6 potter
i tested few 318 before...
is normal to be underpower i guess......
one way to get power is change the final drive..
my previous owner change it...
but this will make u loose more top speed, in return u get more pickup...
i use s button when i need power,but they said its use more fuel but i dont have idea about it
bro, did you test drive the car before you bought it? is it that much difference in power? the 318 97 i used to drive was under powered. from what you've been sharing, you seem to be terribly disappointed with the power. you should have gotten a 328....
the torque should be enough for daily drive.. or even going up genting with 5 adults in the car..
318 under power
Bro bullari, i'm oso using the same ride as yours e36 318 97' model. If I'm not mistaken 318
normally under power at the starting point. But, I try to manipulate it by changing the lower
gear D1,D2,D3 then D4, try to treat it as manual car, just for fun, syiok syiok only. But I do
it once a while, don't want to take the risk to make my gearbox long lasting... huhuh...:listen:
May be our Sifus can give the comments, by doing that regularly, what is the consequences.
I did try switching off my air-cond especially when climbing up hill and it goes reasonably well but I dont intend to do that all the time, Is there any other alternative that I can do to improve it?
change the exhaust system.. use AC Schnitzer like mine :). Change your air filter to open Pod breather or Sport drop in filter. change fuel filter to new one. Change to sport perfomance cam and cam pulley. and lastly install a supercharger unit just like mine oso! haha>:D but the power gain still sucks... so... buy a 328!
aiyo. how much u spend for that mod bro? I'd swap for a 2.5 motor then.. :wink:
after reading all comments.my conclusion,better get 328i.since i haven't had any.thanks.
Confirm something wrong. I can hit 200kmh ler.
Bro chairoger, just kind a curious, r u using e36 318 oso and u can hit 200kmh?
izit easily u can hit 200kmh or took longer time to hit it?
Any upgrade on the engine stuffs? Just want to know. Thanks.
Plain vanilla E36 318i. Long time to reach 200kmh but not impossible if the highway is relatively straight. Cant squeeze anything more than 200kmh though no matter how hard I try. Time for new Bimmer. keke
kacman;383667 said:
..or swap with 2.5 engine:wink:
the other option is to get the 318IS engine ....baby M3 ! easier
on the road tax & puspakom registration .
actually the M42 can chip and "mechanically" tune to 205HP @ 7250rpm on N.A mode...:34: redline at 7700 rpm, imagine the extra 1200rpm allow the e36 318i to go beyond 210km/h !!!! serious!!! :34:, he he he... because nobody know how to do it and not enough budget, even worst the TAX kill it...:34: in Malaysia., soo; everybody there were just only experianced with the japanese 240SX/200SX/SILVIA/VTEC/MIVEC/VTTI ???....:34:
if put in the FORCE INDUCTION...it will goes to 300 Biological Horse Power....:34:
under poer
Have the moolah,go for it
M42 & M44 Engine Prices
M42: E30 (90-91), E36 (92-95), Z3 ‘95
M44: E36/5 318ti (96-98)
E36 318i (96-98) Z3 96-98
2000 Sport M42.......... 160 HP.........$6,495.... 800
2100 Sport M44.......... 170 HP.........$6,795...1200
2100 Rally M42........... 205 HP.........$8,495.... 800
FORCED INDUCTION
1900 FI M42.............. 225 HP.........$6,995.... 800
2000 FI M44.............. 225 HP.........$7,295...1200
2100 FI M42.............. 300 HP.........$8,995.... 800
Pistons & Rings
MM Sport 87mm Forged Alusil Piston M42 1.0:1 CR... $780
MM Sport 87mm Forged Alusil Piston M44 1.0:1 CR... $780
MM Sport 87mm Forged Alusil Piston M42 1.5:1 CR... $780
78mm Moly Rings....................................................$120
Rods & Bearings
Rods
MM Rally 138mm “Ultralite” “I” Beam Rod (475 g)........ $780
MM Rally 138mm “H” Beam Rod (520 g)....................... $700
MM Forced Induction “H” Beam Rods with 4 Squirter Grooves
134.5mm, 137mm or 138mm............................................$780
Rod Bearings
Sport Aluminum Face Bearings..................... $60 per Set
Rally, Forced Induction, Race:
Teflon Coated Tri-Metal............................... $140 per Set
Main Bearings
Mains with 360° Thrust & Oiling Groove:
Requires modifying lock tangs on the main bearing caps ......... $120 per Set
Crankshaft
M42 - 88mm Forged Steel Crank Kit:
For 2100 Rally or 2100 Forced Induction.................................... $1250
Cams
MM Sport Intake Cam 258°Duration/11.15mm Lift...... $780... 250
MM Rally Cams:
Intake 272°Duration/11.4mm Lift
Exhaust 258°Duration/11.15mm Lift..........................$900 Pair 250
MM Turbo Cams:
Intake and Exhaust 272°Duration/11.4mm Lift...... $900 Pair 250
Prices Subject to Change
Core Deposit
Core Deposit
Heads
Include: 6% Flow Increase, Surface Turbulence
Valves, Manganese Valve Guides, MM “Bee HIve”
Valve Springs & Lightweight Retainers
MM M42/M44 Head.................... $1,495........ 600
Components
MM 35mm Hydraulic Lifters....... $30 Each.... $400 Set
MM 35mm Mechanical Lifters..... $40 Each.... $600 Set
Shim Pads....................................................... $5 Each
MM “Bee Hive” Valve Spring
and Retainer........................... $20 Each.... $300 Set
Manganese Bronze Valve Guide.. $12 Each.... $175 Set
MM Socket Head Bolt (100 MM).... $7.50 Each.......$70 Set
Multilayer Stainless Steel Head Gasket
For Forced Induction Engines.......... $7.50 Each.......$70 Set
Bolt-Ons
MM Lightened Flywheel 11 lbs.
& 228mm Clutch Assembly................... $755... 200
(Stock Dual Mass Ring Gear or Flywheel required for core)
Pulse Chamber Intake Manifold (E30)..... $995... 250
Core Deposit
Core Deposit
