uncle aziz
- Dec 3, 2006
- 335
Ori DSP
uncle aziz;565464 said:rm 1200.....fr half cut e38 MSport .....dealer refuse to sell in the first place .
pumpkin76;577039 said:hi uncle aziz,
I read your thread from page 1 till 15.... initially you were saying the speedometer was not functioning and that you've detected the root cause, mind elaborate it a little bit?
reason is, i'm looking at an E30 with a non-functioning speedometer.... trying to figure out the possibilities that causes it other than changing the whole meter?
thanks a lot!
btw, your car looked GREEEEEAAAAAAATTTTTT!!!!!!!
uncle aziz;577070 said:The main culprit is ASC unit....once failure the impact will be driving the car without :
Speedometer /ABS /DSC [Traction Control]/Mileage Calculated/Trip Mileage Meter/Fuel Consumption 1 or 2/
Auto Lock/Cruise Control/Temp Gauge Read 31* - 33* [even though it was much warmer than that]
.....but for e30 might be due to other reason. You can check with e30 forumers .
I also own e30 and once experienced the same problem ....check the connecting cables behind the unit and plug in again, it works
YaZmEeN;577202 said:Uncle,the broken headlight can give me?got some project to r&d with that unit lah...anyway to help u clearing the store...hehe![]()
uncle aziz;576983 said:Ori DSP
uncle aziz;577255 said:Tak jadi masaalah....tapi lambat sikit sbb insurance adjuster hv to check the car once restoration job is completed before they release to me ( to confirm damage parts hv been replaced by workshop authority) ....... will notify you.
I`m still keeping this old design headlight ( still good , no scratch)...WTS cheap.
Sorry to ask...which part of this hdlght set can be used to e38?.. I hv another set similar to this.
uncle aziz;577258 said:The front rubber cover looks ugly......need to press 2 /3 times before locking/unlocking ( changed with new batery) .....looking for replacement . Pl notify
where to get.
uncle aziz;577259 said:Yazmeen> some of button at the air con panel without light.... but all buttons are funtioning. Is this normal?
where to get.
uncle aziz;577442 said:Thanks for yr advise Yazmeen & BimmerE38.....I will try ebay uk.
Anyway how much it cost ?
