Meaning you didn't have this problem with your 15"? I have this problem too, had it ever since I bought the car :hmmmm2:... though not very bad. My mechanic suggested WIDER tires to eliminate this problem :76:, which I tend to disagree as the original e36 had smaller tyres than what I have now. I was thinking probably the steering assembly... some worn linkage or bush etc but if you are sure you didn't have this problem before changing the wheels, it most definitely has to do with that :shakehands:
I am using 18" with 225 front and 235 rear - directional tire tread (which is quite common these days) on my e36. Used 17" before in another e36 and never had any problems.
