HI all
Thank you for all the responses :top:
Now car just went back from repairs :wink:
Went to Berlin Motor Works in Segambut on Saturday
not the best job in the world, but definitely one of the better workshops out there. Friendly service, and reasonably priced :top:
Problems
- Power steering failure
- Power steering fluid leak
- Jerking while driving (Coughing)
Solution
- Turns out that the power steering belt is missing from the power steering pump ( Don't know when has it come off) , no wonder it doesn't work even after I filled in so many power steering fluid n so on ( the host is leaking too :stupid: )
So, just put in a new belt (RM38) and replace the return host which is leaking (Chop shop RM130) ...now the power steering is working flawlessly again :top:..lucky that I don't have to change PW steering pump or whatsoever
- Jerking while driving is caused by one of the spark plug cables are quiet loose n looks like some rats might have bitten the cables..a simplequick job solves the problem temporarily and one of the socket that holds the spark plug is also quiet loose hence the coughing.So now have to find a new cable for the spark plug to replace the current ones.
also changed engine oil and oil filter too..total spent was RM403..mintak kurang dapat RM400 only lol
