Taking video in total darkness
BlackE90
New Member
Tip: Take video in total darkness By Joshua Paul, Author, Digital video hacks 06/23/2006 All sorts of interesting things happen in the dark, but how do you take video of them? These tips will help you shoot video in even the darkest places.It could be a mysterious animal rustling in your garden or the phantom cookie thief who keeps sneaking into the kitchen in the dark of night. Whatever it is, you want to take some video for proof. But how do you do this without turning on the lights? Neither the mystery animal nor the cookie thief is likely to come out if you leave all the lights on and your camcorder running. It might seem like an insurmountable problem, but there are a couple things you can do to take video in poorly lit or dark places. You can either make the most of the light you have, or you can add more light that only your camcorder can see. Use slow shutter speedsBy slowing down the shutter speed of your camera, you give it more time to collect the available light, making more use of the light that is out there. In many situations, such as under streetlights or other indirect lighting, using this slower shutter speed mode can be enough to produce usable video, and most camcorders offer a special Slow Shutter Speed mode. The resulting video can often be rather jerky and blurry, though; much like a still camera, a slower shutter speed exaggerates both camera shake and the movement of the things that you are capturing. You can't do much about the blurring from moving objects, but you can minimize the camera shake by mounting the camcorder on a tripod or holding the camcorder in both hands and leaning against a wall or building. Adding more (invisible) lightThe other trick is to add more light. While this might seem illogical, there are types of light that your camcorder can see but that you (or your subjects) can't. Specifically, your camcorder can see infrared (IR) light, which is invisible to the human eye. Most animals can't see it either, or they aren't bothered by it. To see what I mean, try this: take a remote control, point the end of the remote toward your eye, and press a button. You won't see anything, because your eyes can't see the IR light emitted by the remote. Now try the same thing, but pointing the end of the remote at your camcorder lens. On your camcorder screen, you'll see a brief flash of light from the end of the remote, because the camcorder can see the IR light. And this is what you can use to capture video in situations where there isn't enough light to record normal video: by using IR light, you can illuminate the subject without annoying or distracting it. In fact, this hack has been adopted by some of the camcorder manufacturers themselves. Many camcorders, such as most Sony models, have a night-vision mode that uses a built-in IR light-emitting diode (LED) light. (Sony calls this mode Super NightShot, while Panasonic calls it 0Lux MagicPix.)But this single IR LED isn't all that powerful: it can illuminate things to only a few feet away. This is fine if you are filming another Blair Witch knockoff (and please don't; they may have been funny the first five times, but not anymore), but it's not much use for things that are farther away.
A 39-LED IR illuminator.
If you plan to record anything worthwhile, you'll need something a bit brighter, such as an IR illuminator. Some manufacturers also produce their own illuminators. Sony makes one called the HVL-IRH2 that works with any of its NightShot camcorders and also doubles as a conventional light. However, this works only when connected to the camcorder, and it uses the camcorder's battery. The fact that the illuminator is separate from the camcorder means that you can place it near the subject and leave it, while remaining at a distance with the camcorder. The figure below shows an IR illuminator purchased on eBay. The downside of using IR mode is that your video turns to black-and-white, because the camcorder is capturing only the IR light, not the full spectrum of color light. This does make your video look rather like what you see through the night-vision goggles that the military uses. The figure below shows light emitting from the illuminator; notice the lack of color.
IR light captured using a digital camera.
Get the best resultsIf you are shooting through a window or have other reflective surfaces nearby, turn off the built-in IR light of the camcorder to avoid reflections. And don't get confused if you turn on the IR illuminator and don't see any light coming from it: remember that it emits infrared light that you can't see, so the most you'll see with the naked eye is a very dim red light. These techniques can be useful for keeping an eye on things in low light or total darkness. For example, my wife and I work with feral cats, and many of them don't like coming out when people are nearby. So, we use the IR illuminator and camcorder in night-vision mode to watch them without disturbing them.
The ability to see at night, using IR light.
The figure below is a frame of video taken with a Sony camcorder in very low light, using the Super NightShot Plus mode and the IR illuminator. If you're trying to shoot video of that elusive animal in the bushes, the moon can be your friend. Time your shooting with the full moon, because a full moon can provide enough light to take video if you use the night-vision mode on your camcorder. You can check the phases of the moon at the U.S. Naval Observatory Astronomical Applications Department's site
Wah! Found new hobby ka? Can test your new project in the Stadium car park at non-game days when couples testing out their rides' suspension in the dark.. :p
Thats what I am looking forward to la bro....
Wanna join me tomorrow ah...?
shit, i better be careful now, since Blacke90 has a new toy..
there goes my hill/valley climbs..
