The tyres are staggered with 225/45/17 (F) & 255/40/17(R).
The car has Dunlop (F) & Michelin PS2(R) non run flat.
I am keen on getting Michelins.
In Aust, UK and Spore, the car runs on 225/45/17 all round and the recommended tyres are PS3.
The car which runs on 225/45/17 all round are the non Msport with same size rims all around.
If yours is an M-sport,the rims are staggered,hence the correct size is 225 fronts and 255 rears
However PS3 does not come in 255/40/17.
Therefore I can either get
PS3 225/45/17 (F) 245/40/17(R)
Or
PS2 225/45/17 & 255/40/17
Go get the PS2,correct size and better than PS3 IMHO.
PS3 is not a replacement for PS2 as some might have been misled.
Non run flats costs rm3k less and are more comfy.
The tyre shop owner strongly suggest getting run flatsfor safety. He says 80% of his clients use back runflats.
Are PS2 an overkill for 325. They are usually used for M3.
It is not an overkill.They are great tyres for your car,but if you think you dont drive hard enough,you might want to consider cheaper alternatives. I once had mine on GYA2 (225 and 245) great tyres,but lacks the rear grip as compared to 255s
I have upsized to 19" since and run on CSC3 which are great tyre in dry and wet,but wears very fast.
But there has been a lot of discussion on your 17" tyres,unfortunately are not many options for staggered 17".
some come out with suggestion like GT Radial Champiro HPY and Nexen N8000,they are worth a try though
Should i go for run flats.
90% travel in Pg. only occasionally drive to Ipoh andAlor Setar.
Care to share your expereinces?
Yes,if you dont mind to have a harsh ride and a big hole in the pocket with a little bit peace of mind.I switched to non RFT after both my rear RFT punctured beyond repair.Never regretted since then.But as i travel a lot i have my trusty spare tyre in the trunk,which has saved me at least in few occasions.
