As per the manual page 84:
AUC Automatic recirculated-air control/Recirculated-air mode
Switch on the desired operating mode by pressing this button repeatedly:
- LEDs off: outside air flows in continuously.
- Left-hand LED on, AUC mode: a sensor detects pollutants in the outside air. If necessary, the system blocks the supply of outside air and recirculates the inside air. As soon as the concentration of pollutants in the outside air has decreased sufficiently, the system automatically switches back to outside air supply.
- Right-hand LED on, recirculated-air mode: the supply of outside air is permanently shut off. The system then recirculates the air currently within the vehicle.
If condensation starts to form on the inside window surfaces during operation in the recirculated-air mode, you should switch it off while also increasing the air flow rate as required.
Caution: The recirculated-air mode should not be used over an extended period of time, otherwise the air quality inside the car will deteriorate continuously.
Via the button* on the steering wheel
You can switch between operating modes via a button on the steering wheel, refer to page 11:
- When outside air is coming in, you can use the button on the steering wheel to switch between outside air and recirculated-air mode.
- When recirculated-air mode or AUC mode is switched on, you can use the button on the steering wheel to switch between recirculated-air mode and AUC mode.
