LiteBulb
- Oct 23, 2010
- 189
- 18
recapride model - 2001 e46 coupe sportsfront headlights foglights and side signal lightsit has alot of stone chips, scratches and quite faded. will i be able to buy just the headlights cover itself?rear lightsmy rear brake lights are moulding inside. most probably is water gets seeped in. can the lights cover be opened? are they clipped, or permanently glued?if you guys have a spare set, perhaps can make me an offer mine is e46 pre-facelift coupe white lights.floor matsany luck where i can get all 5 piece floor mats for the coupe? i am looking for those with the hole that i can clip them to the floor. i went to bavarian auto and they only carries sedan mats.windowsi noticed that my windows are not tucking into the frame neatly and not giving a proper seal. when standing outside, sometimes when i closed the door, i will have to push the window to make it tuck in to the frame. could this be the regulator's issue?overhead barinside, the bar where passenger holds over the top, is quite loose. as i drive, will have krok krok krok sound. any experience from you owners on this? if yes, any fix?
