elixir
- May 20, 2008
- 299
chetz;426762 said:hie bro elixir...
thank you for ur intrest... i update my gb progress at this link.. bro tenno also facing the same prob..
http://www.bmwclubmalaysia.com/forums/showthread.php?t=27335
as if i change.... (selector switch, torque converter, pump, gears, clutch plates, seals, bearings, solenoid, valve body, hoses, oil cooler.) as u said.. does it means ive changed everything inside the gb?? from ur experience how much it will cost?
ok, your symptoms seemed to be like mine but the damaged may not be the same.
when the gb is opened, the torque converter is blue in colour. that because of overheating. i was advised to repair the torque converter, change pump, heavy duty clutch plates, seals and some other minor things + software update. that cost about 8k. later on, i changed the 2 hoses and the oil cooler. that's additional 1k+.
for your case, you may not need to changed everything unless you are very unlucky.should'nt cost you more than 10k.
