B33mEr;368983 said:
interesting write up on the effect of exhaust setup on DME ... i didnt know that it would cause the DME to alter it's A/F ratio to maintain thermodynamic efficiency base on the exhaust valve pressure inside the engine and on to the exhaust pipe. I guess thats one of the many function of the o2 sensor ... Am i rite to assume that is the case?
Hey dude, the BMW 's DME is big different from the NORMAL ECU...,
THE DME is a micro computer, i repeat MICRO COMPUTER!!!! it was COMPUTER and had intergrated software to run it, just like you play a computer game, the enemy in the game was run by computer with various AI logic that was very smart
the software in the DME was an engineered calculation (thermodynamic.., alot more)
different software for the M50 cast iron engine and M52 aluminium-magnesium engine...,
two different thermodynamic environment
all the sensor hooked up for the accurate micro-computer calculation, that why my bmw suck
RM 11-13 perday with aluminium alloy 6-barrel 2.8caliber compare to RM10 perday for the HERO 's 4-barrel 1.3 caliber, that was big different!!!
and that why once you had upgrade the exhaust, you will need new and accurate DME software
program (the formula) for the exhaust..., if not ... the M3 gonna lose to the WRX STi again...
All these was german langue and computer software programming
