Mark Loo
- Oct 5, 2009
- 11
Vincent Hor;461779 said:Qoute : this is one which has the 4.3 screen problem which I was talking about.
I have also noticed that these car does not respond to the acceleration, it need both the lower arm changed, oils leaks, gear box mounting need to changed. Rear sensor faulty Unquote
Rajan, Mark, wow, that's some work to be done but then it gives you the bargaining power. Lets face it, there are only very limited perfect or zero repairs cars for sale in the market. Even if you find one, they are usually sold at a premium.
If you are a true BMW enthusiast, you will find joy going to the workshop and better still the fact that you know the car is put back into pristine condition by your own initiatives.
Which part of Sg Buloh? I like to check it out.
Thank you guys for the info. If I do buy this unit, then I'm prepared to put aside some 15k for initial repairs. Dont know whether it is sufficient, but am prepared to take the risk based perhaps more confidently on Vince's or Albert's advise. But bottom line is I must not rush into this deal. Should be comfortable enough when making this purchase.
The car is actually at a used car lot, Edarkar Used Car, along the sungai buloh expressway, leftside heading towards menjalara township. If not too much of trouble, would appreciate if Vince could take a peep at the unit and present useful comments.
Hope to hear from u!
