Notebook in your car
BTW, the infrared scanner that you mentioned. I think you are referring to a thermal scanner. During the SARS outbreak, many country like Malaysia, Singapore and Hong Kong use it to scan people for fever.
and you see too many spy movie. he..he..
I'd be curious how the IR scanner will read when pointed at the trunk of a black car with a notebook iniside the trunk which has been sitting under the hot sun for 3 hours :).
Wouldn't the readings on the surface drown out the "useful" readings you would want to get from whats inside the trunk?
yes the infrared scanner have to be calibrated for the colour surface. I can't remember what the term is called but for dark surface we use a different coefficient compensation. For light surface, we use another coefficient factor to compensate for a more reliable reading.
For a metal surface that is hot, you would most probably get a red spot on the monitor screen with a temperature showing 40 deg plus.
Infrared scanner have been used widely in the power industry. They have been used to check for hot spot on high tension transformers and high tension line.
Loose connection on electrical installation have always been a problem in our power industry. It generate heat and will cause the connection to burn. Other than physically off the supply and retighten the connection, there is no way to do this. For high tension line, you can install the infrared scanner on a helicopter. By recording the images when the helicopter flied over the high tension cable, the data can be analysed later to determine any loose joint/connection.
and IR scanner cannot penetrate metal. The waveform is not ultrasonic.
Hey Jarance.... what do you do for a living? or do just watch too much national Geographic? Have much knowlegde to pick up from you.
The explanation you gave was spot on. Also, as an argument to further enhance this is that the the intencity of the IfRd from your home remote is rather weak. I do not know enough on Ultrasonic applications just that they bounce the signal to get a reading. However, I did come across a device in a catalogue that says that the scanner can be used to scan electrical cables behind enclosures, metal included.
I hope you do not feel that I'm being argumentative, It's just that, you seem knowledgeable and I'm a sucker for anything techie.
Regards
right now.. full time baby sitting this club.. ha..ha..
Seriously, right now baby sitting a dozen or so engineer for a project in the power industry. Aiya.. most of them general knowledge and google a lot.
Me not a techie but into gadgets. prefer to DIY rather than buying it. You should see some of the unfinished thing I have at home.
But anyway, thanks for the compliment.. It is always interesting to have a discussion about technology.
Same here.... cheers mate... btw, which part of KLANG are you from? I'm from Pklg, going back there today
me too! Going today from JB.. Going for the Sapura on Sunday.. Hope to see you there..
taman eng ann is my home..
