theCROW;202831 said:bro sesat,
you can test drive my car if we meet in TT
Yes I was planning to sell it but not anymore hehe guess I'm getting use of the hard ride already. But still pain in the ass for city driving.
LCP;202968 said:sesat88, make sure your chiropractor is on standby if you wanna test drive a car with coilovers... heehee, just kidding...![]()
LCP;202981 said:No lah... just kidding... For street specs coilovers, they can be hard, but usually bearable, unless of course you pandai-pandai (like me) went to specify super stiff damping rates, like what I did to my Satria... I reckon that in a few years time I need to see a chiropractor already... getting a bit too old for this.
And yes, the handling improvement with correctly set up coilovers is simply... priceless.
DanPromote;202822 said:1) hard ride - duh.. what do u expect when u are using coilover? All coilovers are at least 50% stiffer than stock suspension due to their construction
2) leakage - common problem with most brands
3) foreign noise from components after some time of usage .. usually some 'tak tak tak' sound
4) poor service from distributor/factory
On the other hand here are the good points :-
1) unmatched handling, cornering feels like going on rails
2) lifetime servicable - don't need to throw them after 1 year
3) cheap servicing - RM80-100+ to service compared to paying hundreds or thousand for a bilstein
4) braking more responsive
5) cheap compared to bilstein yellow & lowered springs combination (savings of around RM1000)
Moral of the story is, choose either comfort (standard absorbers/springs) or performance (coilovers). You can't have both. Also check the type of warranty given.
I have used a few types of suspension - RG coilovers, Eibach springs + stock absorbers, stock springs + stock absorbers.
The most comfortable, obviously, is using stock absorbers. Somewhere in between is the Eibach springs + stock absorbers, but I find that the car feels too soft. The best handling is coilovers, but bumpy ride.
All setups have their problems :-
1) stock absorbers - feels like driving a boat during hard cornering.. damn floaty, but very comfortable for daily use and slow driving
2) eibach + stock absorbers - have to touch up my front bumper a few times coz too low and soft, car bottoms out on fast and high degree slopes/bumps
3) rg coilovers - feels like schumaker during corners.. 160kmh and I tried flipping the steering wheel left and right over and over and the car still stuck to the ground, but bumpy .. not good for your back. Also needed servicing after a few months due to rear absorber leaking.. surprisingly the front coilovers did not leak .. but did have some foreign noise after a few months.
initialM;203727 said:Guys,
Already check wt Speework JB, coilover step 3 for my E36 cost RM3k. Is it same in KL? They mention oso its bout 20% stiffer than ori shocks and they give 1 time free dampening adjustment.
LCP;203740 said:Price is about there.
Speedworks Penang turned around my Satria's Hotbits coilovers rebuild in just 2.5 hours last Thursday, amazing, that also included removing and reinstalling them back on to the car. Was there all the while to witness the whole process. They even gave me a printout of the actual setting that they dialed in... plenty of washers and shims used though, couldn't understand much of it, except a basic grasp of what each setting is all about. There are simply so many variables that can influence the performance of the shocks. Set something wrong and even though on the new ones where you can adjust the damping rate, you will be in for a funny ride no matter what you did... Mine is the older fixed damping rate type, anything wrong means a rebuild. Rebuild is RM80 per shock, but now they charge labour to remove and reinstall the shocks back, that's another RM80. Worked out to RM400 per rebuild.
Photo of the shock settings, maybe some suspension experts here can explain a bit more about the settings, basically the rebound and compression rate is determined by the size and number of shims/washers, but there are still many factors to influence, eg. gas pressure, bleed ratio, etc:
