leforte;202420 said:
initial m:-
both sets were new and less than 3 months of normal usage and they tried making a claim with RG and was rejected by RG with a reply saying that as long as the absorbers are not stuck they are not claimable. so there's only one word they can tell you....RG SUCKS.
actually rg & hotbits suspension were created by the same designer ie. Rudiber Grebe (RG for short) initially about 10 yrs ago. Both companies took a different direction since Grebe retired but many earlier models share the same design.
Have many friends who owns coilovers and most of them have complaints, even our much talked about local co. Titan has complaints from my friends who bought them as well as the famous Tein. Here's the list of common complaints :-
1) hard ride - duh.. what do u expect when u are using coilover? All coilovers are at least 50% stiffer than stock suspension due to their construction
2) leakage - common problem with most brands
3) foreign noise from components after some time of usage .. usually some 'tak tak tak' sound
4) poor service from distributor/factory
On the other hand here are the good points :-
1) unmatched handling, cornering feels like going on rails
2) lifetime servicable - don't need to throw them after 1 year
3) cheap servicing - RM80-100+ to service compared to paying hundreds or thousand for a bilstein
4) braking more responsive
5) cheap compared to bilstein yellow & lowered springs combination (savings of around RM1000)
Moral of the story is, choose either comfort (standard absorbers/springs) or performance (coilovers). You can't have both. Also check the type of warranty given.
I have used a few types of suspension - RG coilovers, Eibach springs + stock absorbers, stock springs + stock absorbers.
The most comfortable, obviously, is using stock absorbers. Somewhere in between is the Eibach springs + stock absorbers, but I find that the car feels too soft. The best handling is coilovers, but bumpy ride.
All setups have their problems :-
1) stock absorbers - feels like driving a boat during hard cornering.. damn floaty, but very comfortable for daily use and slow driving
2) eibach + stock absorbers - have to touch up my front bumper a few times coz too low and soft, car bottoms out on fast and high degree slopes/bumps
3) rg coilovers - feels like schumaker during corners.. 160kmh and I tried flipping the steering wheel left and right over and over and the car still stuck to the ground, but bumpy .. not good for your back. Also needed servicing after a few months due to rear absorber leaking.. surprisingly the front coilovers did not leak .. but did have some foreign noise after a few months.
