bimmerholic;581467 said:Bro Jarance,
By any chance do you think you could find a way to tap into our I-BUS and read our OBC data?
That's the only thing preventing me to from getting this unit atm. Dowanna loose the OBC readouts by having to replace my MID, unles of course this new hooligan can do what my MID does![]()
jarance;581497 said:At this moment, you cant read the I-bus data cos it is not wired up. The DVD player is only wired to the CAN bus which control the MF on the steering wheel. This is done by the CAN Bus module supplied with the unit.
In theory, it can be done via a I-Bus converter (serial to USB converter) by using the USB port. Data is then tap or read via I-Bus protocol. Once the data can be read, you can then used a customised faceplate to display
the data. btw, this is my next project. Being thinking about it for a long long time.
bimmerholic;581499 said:What a relieve! Had that in my mind ever since some one came up with this awesome player that practically does everything under sun except for just that one thing.
I'm currently looking up foreign forums and googling for leads on anything that relates to this hack!
cheers.
bmw7833;581523 said:Yes, it is do-able. Someone link the MID and put on the compartment.
bimmerholic;581590 said:Got any links to that hack?
bimmerholic;581621 said:thanks for the pic.
That's fine...to relocate the MID and somehow connect it. But the real question is, can the display on that MID be outputted to the Hooligan touch screen so that we can touch and select all the OBC options & display it? Rather than having to open the glove compartment to monitor the OBC. Get what i mean...
ALBundy;581746 said:Jarance, with this it's even better than the OBC !!!
jarance;581817 said:woh, original is selling for USD650.. I found cheap cheap equivalent at 10% of the actual price.
http://bmw-scanner.com/?page=bmw-scanner_v140&lang=eng
Just place order for it.. :wink:
herbert;581821 said:the cheap cheap one....can you provide the link.
