t2ribena
Club guest
- Sep 9, 2006
- 1,773
- 38
Since I found that the stock 530 brakes (324mm disc) on the CKD 525i M-Sports is insufficient and prone to fading if you drive fast and hard for extended time, i started a quest to 'retrofit' the M5 front brake kit (374mm disc). I prefer the M5 brakes because of the 'original' BMW feel
and also the fact that the dics are of compound material compares to the Brembo BBK... Afta doing some research and waiting for opportunity to get one set of the M5 front brakes, i finally received the shipment today and straight i went to get it installed at freddie's place...halfway thru found that the caliper clip was missing...damn but since on the car liau so just use it as it is...no hard braking...
now waiting for the clips to arrive... here are some photos...
the stock front brake...
the M5 brake caliper..it is so huge...
the disc and caliper installed...
another angle...
