e34 brake question
jon3171
hey there, can anyone tell me what brakes can be used on an e34? mine is currently running 520i 12v solid disc and standard calipers.....I happen to have an e28 528i caliper and ventilated disc set lying around...will this bolt on and be useable? if so it should provide a slight braking upgrade right?(owing to the ventilated discs)...IF NOT, what other ventilated discs can i use with the standard calipers? 730i or 735i E32 discs maybe? thanks in advance!
hi jon..try search classified..someone is selling good stuff there..e38 4pot brembo..direct fitment to e34.
thanks for the info bro, but i don't really need 4pot brembos for my car...actually im just looking for a better disc...ventilated type...whichever will be an easy fit...if there is nothing available, i'll just skim the existing ones and reuse.
donno if the e28 brakes will fit.can always try.
the 525' e34 comes with standard vented discs and calipers.i did mine this way.direct bolt on.no fuss.
braking improvement?not if you track your car!
yes, the e28 disc's and calipers can fix, only thing the the e28 disc diameter is smaller then the 302mm e34 dia.
jon3171, you always ask for help/ info in here, meet up la for TT around subang/pj... sure can ask many info....
E38 4pot Brembo ,Who's said can direct fit to E34 ? Must custom make the bracket.
