Alphaville
New Member
- Jan 1, 2015
- 14
- 3
First time owner here... so please bear with me.
Got myself a 2nd hand 2006 523i UK model, recon in 2010. Salesman told me the key fob batteries are weak, need charging. Both fobs can hardly unlock/lock the car, and only works sometimes when I am standing next to the car. After a few days of charging the fob by using the car, it still has not improved. So I started googling and found the following:
1. The rechargeable battery in the fob is the Panasonic VL2020. It is non serviceable, therefore if you want to change, it is a DIY project with replacement battery from ebay.
2. It may not be a battery problem, instead the diversity antenna / amplifier could be failing, or the wiring for the antenna is damaged/loose. Other symptoms for this, besides the remote not working, is the radio reception can get bad.
I am beginning to suspect I have problem number 2 due to a few clues, so my question is where can I send my car (around PJ) for someone to check out the antenna? Don't dare to DIY, the few pictures I saw is a bit daunting cos it involves opening up the C pillar , etc....
Also, if the problem really is the battery, any specialist who can offer their services to have it replaced and reprogrammed?
Thanks in advance....
