seewai;621095 said:Bro, I used to have 1 key to start engine and another key to open after changing EWS. The guy did some magic and now I can use a single key to open door, start engine and the remote is working (lock, unlock, open boot).
It's not cheap to do that, but it's doable.
Cheers.
seewai
To set the remote to open door and boot is very easy as long as your remote control frequency is same with your car then you can set the remote already. The problem is the transponder, because setting the transponder needed a special device to do the job.
