taggnas
- Aug 6, 2007
- 209
Hello All,Today something wierd happened to my Year 2000 E46 gearbox. It was although the gears were stuck in 3rd gear and even when I stopped the car it did not engage to a lower gear (it remained at 3rd gear!). The panel was showing an exclaimation symbol surrounded with gears. I read the manual and it states that if this indication lamp comes on there is a malfunction in the transmission system. All level selector positions can still be engaged, but in a forward driving position only certain gears are actually available when the vehicle is driven. Bring the vehicle to a stop. Move the transmission selector lever to P. Set the parking brake and turn off the ignition - ignition key to position 0. If the indication lamp goes out after a few seconds, normal transmission performance has been restored. You may continue to drive as usual. I did that and now the car and the gears seem fine. BUT I was just wondering if anyone else has experienced this before. Is my gearbox kaput-ing? Or is this just a pretty common problem among E46's. I have been driving slow as I am not too familiar with the roads in Penang!Perhaps the gears were stuck!
