Psykit;719429 said:I'll keep that in mind. A pair or just one side?
initialM;719437 said:congrat bro, nice E39 there
bmw7833;719506 said:Not plug and play..u need the control module.
Lefthanded;719343 said:How coincident... cikgu meet cikgu... hopefully one fine day cikgi will check in as well.... or is there one here already?
bmw7833;719511 said:The light itself is easy to get in the market but not the control module. I am not sure where to get the module. eBay is a good source for u. Without the module, i think u will have the flickering problem.
JFT63;719513 said:hehe, good to meet another cikgu here..ezzo369 is also cikgu..wil try to recruit cikgi soon..kekeke
bmw7833;719556 said:Here is the link u can refer to.
http://www.bmwdiy.info/celis-rear/index.html
They call it as LED voltage regulator instead of control module..![]()
alive88;719540 said:how frequent does it strobe bro? does any error comes up?
bimmerholic;720106 said:No error. Absolutely clean when comes to Cluster Check Control. Initially when you first start, it will strobe alternately between the left and right CELIS in fast successions. Barely a second in between the succession. This lasts for approx 5 secs.
After that, it will strobe once on each side every 20 secs or so.
Why does it strobe in the first place? Simple...
In actual fact, all your others bulbs (filament type) will undergo a cold check monitored by the LCM. What the LCM does is to check if any bulbs are blown every 20secs or so. But since they're Filament type, it will not be able to light up in a fraction of a second unlike LEDs (digital...think 1s & 0s....nothing in between), therefore you will not be able to see any flickering.
However, when LCM does a cold check on the CELIS, it will flicker and of course, you can see it.
alive88;720241 said:thanks bro.. have done some study and they said this could be prevented via cancelling the cold check monitoring in the LCM.. but currently i want to know how those pre FL models that have the CELIS taillights to make it work without flickering.. do u know how bro?
alive88;719505 said:a pair bro.. btw, does it plug n play even if mine is the pre-facelift one?
