Gearbox problem
merz_e46;480116 said:
Just happen last Oct..This is the first time..actually in the morning all ok..when i want to go out again..can't revrse
Last time when the mechanic try to check the transmission when this problem happen..
Not yet flush the radiator..the mechanic told that the water are ok..
The solenoid already clean..nothing there..
RPM going up when in reverse position..i can see when move to R the RPM like normal..before this..when move to R the RPM going up for a second..
It's possible to bring down the GB for check it or..need to send KL..coz im in kemaman now...
You seem to have the problem when the engine is warm up. It look like it is OK when the engine is cool down (morning).
Have you check the thermostat which is located under the expansion tank?
I still don't knew about this problem..whether engine cool down (in the morning) or when after runinng..still can't reverrse..
Pening lahhhhh...Basically...when try to rvrse,its look liker neutral..only can move fwd..
I think..better go to KL..and dianog over there..im still thnikng..maybe not GB
dear all bro's....
sory to interupt......
im using 328 yr2000...but it 2nd hand...
few time the sign come out..but after off n on...there sign went off...
bring to dianose....mechanic said its ok...no problem....
any idea wat happen...i mean the root cause....?
Cannot reverse?... Thats sound unacceptable. What if we park at shopping mall and then when want to go home..cannot reverse. Want to go fwd also cannot coz infront got wall.. Then have to leave the car there and go back by taxi lah......hemmmmm
Make me more worried to own this beauty....lahhh...
Or you can slam it in Neutral and go in front car and tolak belakang. Shoppers will be looking at you very curiously if you were to do that on a UDM.
In return you can bullshite this to them "I'm going green as frequent as i can by not turning the engine over just to reverse" :D
