Enquiry on E38
redbaron;291582 said:
Thank you tu dah la i luv you tu geli la
RB, be careful of tis guy wor , last time he was from a boys' school wor hehehehe
hope u cld find a good transporter yeah
wah main 730... buy la 740.. 730 only seen 2 wen i was on buying spree.. but both bad condition.
ryucky81;385293 said:
hi all, any idea E38 728i 1999 can install sprint booster? thanks
I don't think so. I believe yr car comes wt M52B28 engine which using cable throttle. Sprint booster only applicable to drive by wire engine ie M54. I assume u experiencing sluggish acceleration rite. E38 is a heavy car so its more on cruising mode.:top:
aiya! too bad can't install! yup, it quite sluggish in acceleration. no choice la.:106:
that true, when cruising banyak shiok Ooooo:love::top:
another question to all sifu, E39 rims can fit E38 kah? what is the offset for E38? thinking change rims.
thanks and regards
Pre-facelift has 728, 730,740 and 750. The 728 is running on M5x engine single vanos. The 730 above is M6x which is the V8 and V12 engines.
The facelift has also 728, 730 and above. The 728 is running on M5x engine double vanos and with drive by wire.
Therefore, E38 has the inline 6 which is the M5x engine and V8 which is M6x engines. All should be running the 5 speed computer gearbox.
The difference is the engine, digital aircon, front headlights (grill + bonet + fender + bumper) and rear tail lights.
The E38 has a lot of variance. So, depending on what you can find in the market.
Also there are E38 M-Sport (rims and suspension) or E38 Highline (with all the comfort accessories i.e comfort seats, blinds, and DVD display with GPS)
ALso some E38 comes with EDC or standard suspension.
The E38 runs from 1996 to 2002. Facelift starts from 2000 onwards.
Price ranges from 40k to 100k.
Hope this helps.
initialM;291348 said:
Dear all 7 series sifu,
Can u outline the answer for E38 model below:-
1) How many model available for E38?
2) What r the engine used for each model?
3) What r the difference between pre & facelifted model?
4) What r the yr of production for each model?
5) Roughly market price for each model?
Thanks for yr time & assistance:love:
Hope this helps.
hi bro, mine 1999 728i with M52 double vanos, may i knw how to check it is drive by wire?
thanks
double vanos normally comes with drive by wire. But you can check if there is a trottle cable from your engine.
Hi there.. i have a set of rims for E38. Originall specs for M-Sport set up. 18inch x 8 front & 18x9 rear. complete with tyres for sale. 245/45/18 front michelin pilot sport & 255/45/18 at the rear also with michelin pilot sport, going for rm3500 negotiable. interested can sms me at 014-331 9111
hi all, any idea E38 meter cluster can b repair? mine sm tm show full reading, sm tm no!
thanks all
Hope this helps.
thanx bro for d info..
but juz to check with u..
mine does not come with DVD display(gps) so is mine msport..?but i do have EDC..
juz to confirm wth u bro..
anyway, 730 is only produced from 95-97 only la... and the facelift come in '99
95-96:
730 v8
740 4.0
750
97-01:
728
735
740 4.4
750
