fender63lp68
- Jul 19, 2012
- 101
- 18
Back to my earlier question. Anybody experienced changing their m sport suspension to a bmw performance suspension..? anybody..???
dzuljazz2001;784130 said::listen: nice ride you hv there shlim .. :4: ... :top: ...
shlim8;784121 said:Fender63lp68, if I'm not mistaken, there is no bmw performance suspension (chassis - I think that's what it's called) for the E93. At least that's what I was told when I asked the last time. Only for e92/e90.
Like the other folks said, the e93 will always feel and behave heavier than a e92, but with the kw V2, the handling is much much better than the ori msport crap... As for comfort, it's in general better than the ori msport, but it'll also depend on the height setting you choose and the rebound setting. It can be adjusted to a pretty comfy level.
The rear settings on the ori msport suspension seems to made for the rear to float up and down, like there is no damping when u hit undulating roads... such as the putrajaya area.... and when u do, the traction control lights come on like christmas lights ! ha ha very scary...
I'm now on the v2 on my e93 335i.
Mun;784386 said:Anyone has any knowledge or feedback on local custom specialist RCS ? http://www.rcs-suspensions.com/
Mine 325 Msport is really crap on malaysian roads. not much confidence above 200kmh ( not that i frequently venture to those speed) . Fabulous on smooth roads and corners but not an all rounder.
Hoping to switch soon but have not decided either KW v2 or this RCS. Did check on Titan, but i think it is not in the same league.
RCS quoted 1k cheaper than KW and I think this local boys deserve some attention. They have done a 335 but they have not supply any testimony.
Motorsport Division;784661 said:Dear Mun,
Since RCS suspension has no track record and it is locally made. Price difference is only a mere 1k. I think getting kw is a no brainer right? Not here to promote KW but since so many club forummer is using kw which is made in germany and so far Non complaint abt the adjustable suspension. KW V2 is an all rounder. Comfort while normal driving and stable during high speed and corners.
My personal view is KW beat all the reknown brand such as bilstein b14 or b16 and etc. A set of good suspension will give you a smile on ur face everytime you drive your car.
fender63lp68;784569 said:Bro shlim....thanks for the feedback. Would certainly like to meetup with you if you can.
Daniel E30;821017 said:Am on NON-M Sport stock suspension. With only a small budget, i managed to install HnR sway bars only. So far works well in high speed corners, even on undulating roads during rempit sessions. On highways, even with 4 passengers on board, the car has never bottomed before. Stock suspension should perform worst than M-Sport, but i wonder why so many buddies had bad experienced with m-sport suspensions. However, if budget permits, ill definitely get a set of KW.
SilverBullet;821065 said:simple..because their driving skills not as powderfull as u maa..taking corners 160kmh at gentinghahahaha :vroam:
