E90 325i Gearbox Overhaul
kelvin1703
New Member
Dear All Sifu,
I just found out that my car gearbox had certain issue, which make it my car shifting gear not smooth while accerelating and high fuel consumption.
Initially, the problem detects might due to the vanos not in order or might need to change a brand new, As i send to Ah Lai @ Kuchai after testing, say my gearbox also have some problem which cause slow changing and not smooth on certain gear (i.e. gear 3 and 4).
I being adviced overhaul needed, and being quoted for RM8,500 for the entire package.
Therefore i like ask all sifu here either is it normal for such price? anywhere else advice for overhaul or recondition the gearbox?
Fast response will be much appreciate.
As i just collected my car less than 1 month. And this car already masuk kilang for more than 3-4 times problem such as air cond - hot air (Naidu settled) Air cooling coid, compresor & condesor all change brand new.
Break discs and pads brand new change in M1.
Maybe just my luck not there when i bought it.
Therefore really need your sifu advice before my bill go sky rocket.
Good workshop recommendation much appreciate it.
Thank you.
can try reprogramming your gbox 1st, or get 2nd & 3rd opinion from other bmw specialist.
