Grand
- Jun 4, 2007
- 189
- 16
Hi all, I know there are quite a number of threads on this issue including those in the E90 forum. Mine is a 2005 E60 520i with M54 engine (mileage about 76,000 km). It all started after I changed engine oil to Shell Helix Ultra (5W-40). Prior to that, the previous owner was using Shell mineral oil and there is no issue of white smoke belching out from the exhaust. About 1-2 weeks after the engine oil change, i noticed white smoke coming out from the exhaust in the morning when I start the car, not every morning but maybe about 3 times in a week. If I drive the car around (in town) for quite a while in start stop traffic, white smoke would again come out when I start to move the car from standstill or traffic light. It doesn't happen frequently but just occasionally at the moment, enough to embarrass me. Coolant level is normal. Engine oil dropped slightly, something like about 3mm. No milky colour on the oil cap or coolant cap. Brought the car to a recommended BMW workshop in PJ area and they checked one of the spark plugs which has some carbon deposit. The owner opined that the engine is consuming the oil which is of lower viscosity grade now and advised me to pour in thicker oil additive like Bardahl 2 to stop or slow down the oil consumption before the next oil change which he suggested I use a thick mineral oil, possibly 50 grade like what the previous owner did to see whether there is any improvement. I know this involves possibly valve seal or gasket and a top overhaul would be due quite soon but pending that, is it advisable to pour in those thick oil additive like Bardahl 2? Already read carbibles.com and they normally advise you against using such additives. Put the said opinion to the owner of the workshop but he said it is quite safe to use. Would appreciate your input and opinion, thanks.
