E60 lci
louiswaw
Hi anybody there fix these lci tail lights ???im frm penang, know where to get it ?
E60 LCI conversion
LCI headlamp rm4k / Tail light rm3k, Ori hella from germany include ballast & module setting, installation cost rm300
sunway got.....RM9.5k with m-tech bodykit and lci tail lights with module.... all original.... inclusive of paint job... :)
if u just want the lights, buy Hella OEM from estimated RM800 per side, so is RM1600.00
Then buy Bruce V6 Cable sets at about GBP250.00
Install yourself and total should be about 1600 + 1200 = 2800
installation very simple.
jack
Just make sure whenever these aftermarket tail lights are added, they fit tightly into the body otherwise you may have water leaking into your boot area thru the uneven gap between the lights and the gap. My previous ride faced similar problem when I changed the rear light resulting in water leaking into the electronic area at the right hand side of the boot. Once i thought the fuel pump is gone but upon checking it was the relay or fuse which was located at that area which was spoilt by leaking water.
