E60 523i Magnesium engine noisy got way to solve it?
feiyuan83
I'm just bout my 523I it seenvery noisy in engine..ta ta ta ta ta sound.. N I just change the oil to liquid morly but the sound also noisy.. Izzit that a way that can solvethis problem?....the sound like a kancil engine ta ta ta ta.. I'm really feel sad bout it ..plese give me an advice.
feiyuan,
The noise is certainly caused by the hydraulic tappet (lifter). One of the solutions that I read from a BMW blog is to add engine additives such as Liqui-Moly Tappet Stop Noise Lubricant. I think you can go to spare parts shops to buy this type of engine additive. Give it a try as it won't do any harm to your engine.
View attachment 26786View attachment 26787
Herbert;778459 said:
feiyuan,
i have seen this during visit BMworld Tun Razak last week, its scary me, engine sound really terible, Ah wai said the owner want burn his car alrdy coz very frustrated with engine condition, still very low mileage...pity owner,
sorry typing error..
Thats why once in a while you need to go rempit, to burn off those residuals. Some called it the 'Italian Tune-Up'.
feiyuan83;778603 said:
i just use 1week truely molly oil become like this
Your engine also has a serious sludge problem. If sludge continue to build up, your engine may just seize up. Suggest you use mineral based engine oil and change the engine oil & oil filter every 2k km to flush out the sludge.
Need to change filter n oil every 2k... Waoo... Must mus mineral base oil to clean up the sluge......
Tmr I will go to work shop n open up the cover en see inside actually what going on.. Will update pic tmr...
frend of mine on E90 325i N52, oso have same problem.. tap tap tap sound... but it's not all time its happen. mostly during morning time when the engine is cold. he went to dealer then left car to check, the dealer couldn't found any problem.. diagnose oso no error appear.
i think you better go and do sameting fast, later on your can cant move a all, coz the oil cant circulate at all. Ah wai, in case like over sludge case..total overhauo is last medicine,,top overhaul coudnt help anymore..
Myenjgine had check out dy...
My cam rm 2400
Carrier rm 430
Lifter rm 60per pcs x12 rm720
Gearl box oil rm 420 for 5 little
Water pump rm 1400
Top gasket rm 97
Labour rm 600 for chnge allthose thing it couse me around 6k++ I just bout it now become like this f....
feiyuan.....no pics aaarr?
these cars were under the bsri (BMW service n repair inclusive) programme when sold by bmw new.the oil chg interval was set at every 15k kms or 20k kms:stupid:.where got oil can tahan 20k kms wan?so now you are facing the effect of the service programme.
before spending rm6k....i wud do an engine flush.....or 2....or 3 flushes.....to clean up the sludge and see how it it goes.....
just hope yr engine internals not like this....oherwise koyak.......
images
images
images
Always change eng oil every 5k kms.....i wish u the best of luck, hope it is not severe sludge prob....
