E46 parts & maintenance
Ignition Coil - RM77x2=RM154
Air filter - RM60
Radiator coolant - RM32
Labour - nil (diy)
Total RM246
Syed6329
Bro care to share where did you buy those items? Price is the lowest I have seen except coolant
AS.. I bought it at BA Subang.. I did called Bomin and BA Tmn Maluri they give me RM80/piece for ignition coil..
Air filter - RM60
Labour - nil (diy)
Total RM246
What are the symptoms which you felt that make you change ignition coil ?
- - - Updated - - -
Air filter - RM60
Labour - nil (diy)
Total RM246
Previously i did changed 2 coils and the workshop charged me RM180/piece..really shock when i know the actual price...here is the list of the bill..
Ignition coil- RM180x2=RM360
Spark plug- RM120
Diagnose- RM120
Labour- RM120
Total- RM720
- - - Updated - - -
Spark plug- RM120
Diagnose- RM120
Labour- RM120
Total- RM720
Terry8...at first my engine runs with 3 cylinder so send to workshop and they changed 2 coils..but few weeks later rpm a bit jumping like misfire when car is not moving and no power..doing a research and they said it might be MAF sensor dirty so buy CRC MAF cleaner and clean it but still the same..so expecting another 2 coils spoil..go to BA buy the coil and change it..now engine run smooth..happy and save my pocket too...
Yea bro..ignition coils must be changed all at one. One will fail after one another.
Sent from my Nexus 4 using Tapatalk 4
Bottom hose - RM 165
Big Hose - RM 350
Labour - RM 80
Total - RM 595
- - - Updated - - -
Big Hose - RM 350
Labour - RM 80
Total - RM 595
- - - Updated - - -
1.GB repair kit - RM 1200
2.Washer - RM 120
3.Fly oil seal - RM 110
4.Waterpump -RM 180
5.GB Oil cooler -RM 420
6.Waterhose - RM 175
7.Centre bearing-RM 150
8.Bush -RM 80
9.Fan belt bearing - RM 90
10.Belt tensioner - RM 170
11.Fan belt - RM 70
12.ATF Oil 7 ltr @ RM 38 - RM 266
13.Cooler radiator oil 2 ltr- RM 76
14.Auto filter RM 80
15.Workmanship - RM 800
Total : RM 3987 discount RM 87= RM 3900
1 month warranty on GB
hammer1911;849330 said:
- - - Updated - - -
2.Washer - RM 120
4.Waterpump -RM 180
8.Bush -RM 80
11.Fan belt - RM 70
Where do you did it?
- - - Updated - - -
- - - Updated - - -
2.Washer - RM 120
4.Waterpump -RM 180
8.Bush -RM 80
11.Fan belt - RM 70
My E46 318i year 2001 (pre-facelift) indicator light housing keeps coming off because the bracket broken already. Need to find a new set.
Any advise where to get?
- - - Updated - - -
Air Cond Compressor (2nd hand) - RM 900
A/C Belt. - RM 85
A/C Gas. - RM 100
A/C Receiver Dryer. - RM 183
Labour. - RM 280
Total. RM 1548
- - - Updated - - -
Any kereta potong or new from BOMIN/Munich/BA Jalan Ipoh. Good luck
- - - Updated - - -
anaksarawak;816139 said:
As preventive and based on BMW SC schedule I need to replace the followings
Control arm bush RM 120 (M3) from Munich segambut
Long shaft bush (coupling) SGD 32 Lamforder from eng soon
Long shaft bearing BMW original SGD 65 from eng soon. You can also get febi from Munich segambut for RM80
Labour at autocraft sunway (ah loon) rm230 inclusive wheels alignment
Has anyone here buy from Commer Range SB located at Kepong Entrepreneurs Park (Tel 03-6252 4262)? On Eng Soon's website, it's claimed that CR is an associated company - so I gather that whatever Eng Soon stocks CR will has them too.
Control arm bush Febi - RM220
Oil pan gasket - RM55
Rear brake pad - RM96
Oil filter - RM46
Castrol magnatec 10/40 - RM100
Liqui moly lifter additive - RM50
Labour -RM300
Oil filter - RM46
Labour -RM300
Bro, why do u need lifter additive? To reduce sound of hydraulic lifter?
Yes bro..just want to try..so far the sound a bit silent compare before this..
