4/6/07:
took delivery of my E46 318i M43
16/6/07:
Cobra alarm system (metalink) - RM1650
30/6/07: (24,000 km service)
5 ltr engine oil - 112.50
1 pcs oil filter - 35.00
4 pcs plug - 140.00
1 pcs air cond micro filter - 98.00
1 pcs fuel filter - 88.00
1 pcs auto filter (atf) - 125.00
1 pcs auto gasket (atf) - 55.00
1 set front disc pad - 175.00
1 pcs front disc pad sensor - 45.00
7 ltr atf oil (ori) - 455.00
radiator coolant - 30.00
labour (for major service) - 160.00
wash - 20.00
TOTAL= 1,538.50
14/7/07:
power window rear left - 370.00
18/8/07:
alignment - 37.50
4 valves - 20.00
4 michelin xm1 205/60r15 - 1060.00
TOTAL = 1,117.50
10/9/07
vkool elite & v40 - 2600.00
1 set crystal no plate & casing - 170.00
TOTAL = 2,770.00
19/10/07
repair 7" crackline - 200.00
27/10/07 (36,000 km service)
4ltr engine oil fully synthetic & oil filter - 190.00
top hose - 140.00
expansion tank - 300.00
TOTAL = 630.00 (including labour)
12/12/07
3 lightbulbs (rear) - 15.00
31/12/07
front brakepad (ate) - 160.00
front lower arm bush - 350.00
alignment - 50.00
adjust rear camber - 50.00
off wheel balancing - 32.00
on wheel balancing - 16.00
TOTAL = 665.40 (plus tax & labour)
18/2/08
1 h7 headbulb - 28.00
22/3/08 (48,000 km service)
oil filter + 4ltr engine oil + labour - 190.00
22/3/08
bought @ inner power
rear ate disc pad - 115.00
rear brembo brake disc set - 310.00
TOTAL = 425.00
labour charge to change rear brake pad & brake disc - 70.00 (on 1/4/08)
31/3/08
alignment & balancing - 155.40 (plus tax & labour)
5/4/08
new alpine ida-x001 ice+speakers - 3,000.00
17/5/08
re-spray right hand side of the car - 600.00
2/7/08
19/7/08 (60,000 km service)
4 ltr mobil 1 engine oil - 198.00
1 set auto filter & gasket - 168.00
6 ltr ori auto oil (atf) - 270.00
labour - 120.00
TOTAL = 791.00
27/8/08
1 pcs radiator assy - 750.00 (plus labour)
3 ltr coolant - 60.00
TOTAL = 810.00
30/12/08 (72,000 km service)
oil filter - 28.00
labour - 35.00
TOTAL = 63.00
31/12/08
alignment & balancing - 181.65 (plus tax & labour)
2/1/09 (yet to be installed)
brembo front brake disc set - 350.00
front disc pad set - 130.00
TOTAL = 480.00
labour to install the disc and pad - 160.00 (on 21/2/09)
17/1/09
re-setting alarm system - 350.00
29/4/09
connector pipe for coolant - 58.00
coolant hose (rear) - 175.00
labour - 85.00
TOTAL = 318.00
10/6/09
(labour) oil filter housing gasket & O ring - 90.00
gasket - 28.00
2 pcs O ring - 20.00
1 pcs belt - 70.00
TOTAL = 208.00
06/07/09
re-spray 16' rims 4pcs - 200.00
11/07/09 (84,000km service)
oil filter - 45.00
labour - 45.00
TOTAL = 90.00
01/08/09
labour - 60.00
fr lh window lifter - 430.00
TOTAL = 490.00
06/08/09
fr h7 lamp bulb - 38.00
15/08/09
205/55/zr16 michelin pp2 4 pcs - 1,688.00
steel valves 4 pcs - 48.00
balancing, alignment, camber - 143.00
TOTAL = 1,886.15 (plus tax)
18/01/10 (96,000km service)
1 pcs oil filter - 45.00
4 pcs bosch spark plug - 140.00
2 pairs brake pad (front & rear) - 370.00
2 pcs brake sensors - 76.00
oil service - 45.00 (oil self-supplied)
labour - 260.00
TOTAL = 936.00
05/02/10
top up air-cond gas - 50.00
02/03/10
1 pc front emblem - 52.00
2 pcs grommet for emblem - 6.00
TOTAL = 58.00
13/04/10
front R/H window lifter - 430.00
labour - 80.00
TOTAL = 510.00
20/04/10
ignition coil - 520.00
diagnose engine misfire & labour - 60.00
TOTAL = 580.00
03/05/10
air vent valve - 185.00
labour - 45.00
TOTAL = 230.00
18/05/10
air filter - 38.00
microfilter - 65.00
(self installed)
TOTAL = 103.00
12/06/10
alignment + balancing = 183.75
17/06/10
front right hand bumper bracket = 130.00
03/07/10 (108,000km service)
engine oil - 209.00
oil filter - 45.00
rear left wheel bearing - 135.00
brake fluid - 38.00
labour - 305.00
TOTAL = 732.00
12/07/10
alignment - 131.25
14/08/10
ori wiper set - 110.00 - self DIY
front windscreen lower panel cover - 228.00 (installed on 13/11/10)
TOTAL = 338.00
13/11/10 (120,000km service)
engine oil - 209.00
oil filter - 45.00
deflect pulley 2pcs - 140.00
fan belt - 65.00
labour (service + install windscreen cover) - 90.00
TOTAL = 549.00
19/11/10:
4 pcs 225/45r17 Eagle F1 Asym - 2060.00
(installed on 3/1/11)
3/1/11:
steel valve - 10.00
alignment - 125.00
fix new tires - 48.00
balancing - 20.00
TOTAL = 212.65 (plus tax)
29/1/11:
oil sump gasket - 55.00
drain & replace oil - 25.00
labour - 180.00
TOTAL = 260.00
26/3/11:
1 set front brake pad - 280.00
2 front brake disc - 520.00
brake fluid - 35.00
2pcs engine mounting - 290.00
FLH lower arm - 150.00
labour - 100.00
TOTAL = 1,375
13/4/11:
1 set of wheel locks - 135.00
14/5/11 (132,000km service)
engine oil - 198.00
oil filter - 28.00
labour - 20.00
TOTAL = 246.00
27/6/11: (self installed)
1 bulb - 3.00
rear boot lighting set - 175.00
TOTAL = 178.00
3/9/11:
whole car re-paint - 2+++.00
8/9/11:
valve cover gasket - 40.00
oil filter housing gasket & o ring - 22.00
U seal - 25.00
labour - 150.00
TOTAL = 237.00
8/10/11:
trunk lid grip - 410.00
(self installed)
13-19/11/11:
new leather seats cover
re-upholster roof lining
RM2,800.00
24/11/11:
coolant - 30.00
8/12/11 (144,000km service)
4L engine oil - 198.00
oil filter - 28.00
1 set lower arm bush - 220.00
1pc R/H lower arm - 150.00
fuel filter - 65.00
oil level sensor - 200.00
ATF gasket & filter - 180.00
5L ATF gear oil - 300.00
bypass air-bag - 80.00
labour - 125.00
TOTAL = 1,546.00
28/12/11:
1pc valve (spare tire) - 4.00
alignment - 125.00
balancing - 56.00
TOTAL = 185.00 + 6% GST
31/3/12:
thermostat - 195.00
radiator cap - 45.00
emission control air pump hose - 150.00
labour - 30.00
TOTAL = 420.00
23/4/12:
battery - 320.00 (it finally died on me after almost 5 years of daily usage)
3 bulbs - 11.00
labour - 30.00
TOTAL = 361.00
12/5/12:
expansion tank - 240.00 (last change was in 2007)
labour - 40.00
TOTAL = 280.00
29/6/12: (installed on 30/6/12)
Front
L&R spring strut - 620.00
2 pcs protection tube - 30.00
2 pcs add absorber - 50.00
2 pcs guide support - 140.00
Rear
2 pcs shock absorber - 320.00
2 pcs guide support - 60.00
TOTAL = 1,300.00
30/6/12:
4L engine oil - 208.00
oil filter - 28.00
labour - 150.00 (including install all 4 absorbers)
TOTAL = 386.00
27/7/12:
1 set front brake pads - 150.00
1 set rear brake pads - 145.00
front & rear brake sensors - 70.00
brake fluid - 35.00
labour - 50.00
TOTAL = 450.00
15/9/12:
cylinder pipe connector - 55.00
block pipe connector & o-ring - 65.00
water hose cylinder (heater) - 130.00
water hose bypass - 130.00
coolant - 18.00
air hose vacuum cover - 30.00
air mass sensor - 450.00
labour - 100.00
TOTAL = 978.00
07/01/13
alignment & balancing etc - 181.00
TOTAL = 191.85 (plus GST)
05/02/13
oil filter - 28.00
labour - 20.00
TOTAL = 48.00 (free oil from AD)
02/03/13
rear left reverse light assembly - 175.00
(self installed)
06/03/13
top hose - 165.00
coolant - 18.00
labour - 80.00
TOTAL = 263.00
03/04/13
alternator (valeo) - 1,100.00 (the old one lasted for 12 years)
labour - 40.00
TOTAL = 1,140.00
15/04/13
u-seal timing cover - 25.00
oil filter housing o-ring & gasket - 22.00
timing cover gasket - 30.00
thermostat 0-ring - 8.00
rear boot logo - 25.00
labour - 150.00 (to replace timing cover gasket, oil filter gasket & o-ring)
TOTAL = 300.00
17/06/13
spark plug ignition cable (4pcs) - 240.00
