E46 parts & maintenance
Mini jeff67
Texstar pads not so mahal bro should be around 120-130 per pair
Kikal
Your price is 20% higher IMHO
always welcome a 'thank' if you like my post!
Good day all. I'm a new member from kluang, johor. Need some info for price of changing these items: 1) flywheel oil seal 2) crank shaft oil seal 3) power steering hose Already asked outside mechanic about the price. He asking for rm1xxx. Is it the appropiate price? Thanks all
Yeow;n1325671 said:
Your right brake light bulb burnt already.
Thanks Yeow. But i already checked the bulb n its ok. Wiring also ok. This indication light up sometimes only.
This occurs to me at times ......sometime weather does plays a role....especially heavy rains...but it goes off by itself later. Probably short circuit somewhere.
If it does not off say more than a day or so...see your mechanic
Mine goes on and off randomly for about a month and then burnt itself out. Cheap to replace though. Around RM5 for the bulb.
I also remembered the dash light could be triggered by the tail lamp ground wire melting the power connector. Common for E46 but not sure your ride is E46.
Lately labour fees has gone up...I normally did normal service where I brought engine oil and filer and labour is now RM80 and previous was RM50. I did at the usual workshop in Subang....most of you know him/his place M.
Is this the norm pricing elsewhere?
Hi guys...
I am new in Johor Bahru. Need to know where is a good workshop to service my E46 Ci ...
Appreciate your views ... Thank you...
Is there anything else being done besides changing oil & filter? RM80 is definitely too high, in fact even RM50 is high enough. I always do it just for RM10, but I am in East Coast. Hehe.
Sent from my Nexus 4
It cost me RM1600 :motz: for N46 engine swap labour cost in Johor, normally RM1000 should be suffix. All others related cost ie engine oil, filters, hose, plugs, etcs total up to RM1044 :stupid:
My fan decided to fail on me during balik kampung drive... Grrr... I ll be in Kedah, need to find a workshop in that area to replace the fan.
Anyone has any idea where can i find workshop that open on Second day of Raya, northern area?
How much is the cost to replace the fan?
Hey guys,
Anyone have experience to rewrap the fabric of the rooftop and pillars? Local workshop quoted me for rm580... any thoughts? I'm from penang btw...
Thanks!
Hi Anthonyhor,
I've done this before and it cost me RM450. Black fabric material. But I get it done in Manjung, Perak.
anthonyhor said:
Hey guys,
Thanks!
ejat shafiq said:
Hi Anthonyhor,
Can you provide more info about shop name and phone number? Just in case I go around that area...
Preventive maintenance.. Parts from Bomin Auto
1. Heat exchanger (gearbox) - Rm 450
2. Oil cooling pipe inlet and outlet (secondhand) - Rm 250
3. Heat exchanger (engine) - Rm330
4. Gasket and profile gasket - Rm40
