Herbert
Well-Known Member
- Sep 8, 2009
- 4,443
- 83
ashabmy;711507 said:My 328 alternator kaput, changed with new Valeo, cost me RM1550. Reasonable kah?
Now my R gear does not engage, happen 3 times alrdy since CNY. Mech suspects the sensor or relay is about to kaput? My 328 is @ workshop to find the actual problem. No malfunction sign appear. Anyone experience b4? Gear D & N no issue
I had similar "R" problem few months ago after going through heavy thunderstorm. Apparently water/moisture slipped into the connector (connecting GB to ECU that is located underneath carriage next to GB) causing "Trans Fail prog". Opened up the coneector, sprayed some WD 40 and then use diagnostic scanner to erase the error code.
