E46 parts & maintenance
ARB Links : RM83 x 2 = RM166 (Bomin and Bav Auto)
Quotation from Bomin Auto
Lemfoeder Tie Rod = RM180 x 2 = RM360
here's another hole in my pocket:
1-mount plate RM250
2-pipe connector RM80
3-Bearing RM120
4-labour RM150
5-semi eng oil RM135
6-oil filter RM30
7-Emblem RM60
service done at Autobahn in SUnway..ni9ce sevice...recomanded for others bemeerian:top:
gimli;700894 said:
Expansion Tank:RM156
Labor+Diagnostic:RM150
Done at WP Auto
What diagnostic got to with expansion tank? Its not that hard to replace the tank. Quite steep charges there
he cleared some errors which popped up when i removed the center console (wanted to clean the melted rubber) & disconnected the ASC button. Agreed, the service charge was quite steep.
There is always a unexpected surprise everytime I visit the workshop for simple oil change. 2004 E46 325i M54B25 @100,950km Workshop bill for today:
1. New ZKE Module (General Module V) - RM2,300.00
2. Gearbox oil heat-exchanger (mini radiator) - RM473.00
3. Oil Cleaner - 2xRM45.00
4. Fuel system cleaner - RM45.00
5. Nano engine protection addictive - RM76.00
6. Ravenol 5W-40 Fully Syn(5Liter) - RM260.00
7. Ravenol 5W-40 Fully Syn(1 Liter) - 3xRM62.00
8. Oil Filter - RM48.00
9. Gasket seal for power steering hose - 4xRM8.00
10. Dextron VI ATF fluid (1 liter) - RM48.00
11. Labour RM200.00
Total damage = RM3,758.00
Inside view of the ZKE (General Module V)
ZKE view in the console box
Sign of ZKE module deteriorating: Wing mirror control some time fail; Alarm sometime buzz without any event. Must be some IC chips or transistors got problem.
Ahyak.....but new electronic parts feel safer. The new one come with new improved software update. Btw, I already get the CD changer working via Ah Onn. Now he know how to do it for the rest.
Of course new one safer..
Yes, he already called me just now. Thank bro and trouble u for few times.
what is wrong with the GM?
Yup I bought them new also but cheaper than yours. Actually its design faulty on the parts. For me i got my old module reconditioned after bought the new one. And the reconditioned one is as good as new as tested for 1 mth in a car. I have no choice but to change new. Even used one from chop shop cost rm700 to rm800. The module is to control all car body function ie central lock. Jialat la only driver side can open manually. I wont spend rm2.3k for that module. E46 is not as complicated as E60 or E90. Anyway anyone need them pls refer below link. Thanks
http://www.bmwclubmalaysia.com/forums/showthread.php?44792-FS-E46-General-Module
As answered.
4/6/07:
took delivery of my E46 318i M43
16/6/07:
Cobra alarm system (metalink) - RM1650
30/6/07: (24,000 km service)
5 ltr engine oil - 112.50
1 pcs oil filter - 35.00
4 pcs plug - 140.00
1 pcs air cond micro filter - 98.00
1 pcs fuel filter - 88.00
1 pcs auto filter (atf) - 125.00
1 pcs auto gasket (atf) - 55.00
1 set front disc pad - 175.00
1 pcs front disc pad sensor - 45.00
7 ltr atf oil (ori) - 455.00
radiator coolant - 30.00
labour (for major service) - 160.00
wash - 20.00
TOTAL= 1,538.50
14/7/07:
power window rear left - 370.00
18/8/07:
alignment - 37.50
4 valves - 20.00
4 michelin xm1 205/60r15 - 1060.00
TOTAL = 1,117.50
10/9/07
vkool elite & v40 - 2600.00
1 set crystal no plate & casing - 170.00
TOTAL = 2,770.00
19/10/07
repair 7" crackline - 200.00
27/10/07 (36,000 km service)
4ltr engine oil fully synthetic & oil filter - 190.00
top hose - 140.00
expansion tank - 300.00
TOTAL = 630.00 (including labour)
12/12/07
3 lightbulbs (rear) - 15.00
31/12/07
front brakepad (ate) - 160.00
front lower arm bush - 350.00
alignment - 50.00
adjust rear camber - 50.00
off wheel balancing - 32.00
on wheel balancing - 16.00
TOTAL = 665.40 (plus tax & labour)
18/2/08
1 h7 headbulb - 28.00
22/3/08 (48,000 km service)
oil filter + 4ltr engine oil + labour - 190.00
22/3/08
bought @ inner power
rear ate disc pad - 115.00
rear brembo brake disc set - 310.00
TOTAL = 425.00
labour charge to change rear brake pad & brake disc - 70.00 (on 1/4/08)
31/3/08
alignment & balancing - 155.40 (plus tax & labour)
5/4/08
new alpine ida-x001 ice+speakers - 3,000.00
17/5/08
re-spray right hand side of the car - 600.00
2/7/08
19/7/08 (60,000 km service)
4 ltr mobil 1 engine oil - 198.00
1 set auto filter & gasket - 168.00
6 ltr ori auto oil (atf) - 270.00
labour - 120.00
TOTAL = 791.00
27/8/08
1 pcs radiator assy - 750.00 (plus labour)
3 ltr coolant - 60.00
TOTAL = 810.00
30/12/08 (72,000 km service)
oil filter - 28.00
labour - 35.00
TOTAL = 63.00
31/12/08
alignment & balancing - 181.65 (plus tax & labour)
2/1/09 (yet to be installed)
brembo front brake disc set - 350.00
front disc pad set - 130.00
TOTAL = 480.00
labour to install the disc and pad - 160.00 (on 21/2/09)
17/1/09
re-setting alarm system - 350.00
29/4/09
connector pipe for coolant - 58.00
coolant hose (rear) - 175.00
labour - 85.00
TOTAL = 318.00
10/6/09
(labour) oil filter housing gasket & O ring - 90.00
gasket - 28.00
2 pcs O ring - 20.00
1 pcs belt - 70.00
TOTAL = 208.00
06/07/09
re-spray 16' rims 4pcs - 200.00
11/07/09 (84,000km service)
oil filter - 45.00
labour - 45.00
TOTAL = 90.00
01/08/09
labour - 60.00
fr lh window lifter - 430.00
TOTAL = 490.00
06/08/09
fr h7 lamp bulb - 38.00
15/08/09
205/55/zr16 michelin pp2 4 pcs - 1,688.00
steel valves 4 pcs - 48.00
balancing, alignment, camber - 143.00
TOTAL = 1,886.15 (plus tax)
18/01/10 (96,000km service)
1 pcs oil filter - 45.00
4 pcs bosch spark plug - 140.00
2 pairs brake pad (front & rear) - 370.00
2 pcs brake sensors - 76.00
oil service - 45.00 (oil self-supplied)
labour - 260.00
TOTAL = 936.00
05/02/10
top up air-cond gas - 50.00
02/03/10
1 pc front emblem - 52.00
2 pcs grommet for emblem - 6.00
TOTAL = 58.00
13/04/10
front R/H window lifter - 430.00
labour - 80.00
TOTAL = 510.00
20/04/10
ignition coil - 520.00
diagnose engine misfire & labour - 60.00
TOTAL = 580.00
03/05/10
air vent valve - 185.00
labour - 45.00
TOTAL = 230.00
18/05/10
air filter - 38.00
microfilter - 65.00
(self installed)
TOTAL = 103.00
12/06/10
alignment + balancing = 183.75
17/06/10
front right hand bumper bracket = 130.00
03/07/10 (108,000km service)
engine oil - 209.00
oil filter - 45.00
rear left wheel bearing - 135.00
brake fluid - 38.00
labour - 305.00
TOTAL = 732.00
12/07/10
alignment - 131.25
14/08/10
ori wiper set - 110.00 - self DIY
front windscreen lower panel cover - 228.00 (installed on 13/11/10)
TOTAL = 338.00
13/11/10 (120,000km service)
engine oil - 209.00
oil filter - 45.00
deflect pulley 2pcs - 140.00
fan belt - 65.00
labour (service + install windscreen cover) - 90.00
TOTAL = 549.00
19/11/10:
4 pcs 225/45r17 Eagle F1 Asym - 2060.00
(installed on 3/1/11)
3/1/11:
steel valve - 10.00
alignment - 125.00
fix new tires - 48.00
balancing - 20.00
TOTAL = 212.65 (plus tax)
29/1/11:
oil sump gasket - 55.00
drain & replace oil - 25.00
labour - 180.00
TOTAL = 260.00
26/3/11:
1 set front brake pad - 280.00
2 front brake disc - 520.00
brake fluid - 35.00
2pcs engine mounting - 290.00
FLH lower arm - 150.00
labour - 100.00
TOTAL = 1,375
13/4/11:
1 set of wheel locks - 135.00
14/5/11 (132,000km service)
engine oil - 198.00
oil filter - 28.00
labour - 20.00
TOTAL = 246.00
27/6/11: (self installed)
1 bulb - 3.00
rear boot lighting set - 175.00
TOTAL = 178.00
3/9/11:
whole car re-paint - 2+++.00
8/9/11:
valve cover gasket - 40.00
oil filter housing gasket & o ring - 22.00
U seal - 25.00
labour - 150.00
TOTAL = 237.00
8/10/11:
trunk lid grip - 410.00
(self installed)
13-19/11/11:
new leather seats cover
re-upholster roof lining
RM2,800.00
24/11/11:
coolant - 30.00
8/12/11 (144,000km service)
4L engine oil - 198.00
oil filter - 28.00
1 set lower arm bush - 220.00
1pc R/H lower arm - 150.00
fuel filter - 65.00
oil level sensor - 200.00
ATF gasket & filter - 180.00
5L ATF gear oil - 300.00
bypass air-bag - 80.00
labour - 125.00
TOTAL = 1,546.00
28/12/11:
1pc valve (spare tire) - 4.00
alignment - 125.00
balancing - 56.00
TOTAL = 185.00 + 6% GST
Lost my power steering... I suspect pump gave way...
Gonna go fix and will post the damage later...
Called Bavarian auto and got a quote on the pump...
aidilj;702417 said:
Thanks aidilj for the link to the great posts on GM V module. Actually I did some layman background reading on this GM V/ZKE module, but after seeing the PCB layout and not too sure about which relay and/or transistor for problem, I took the plunge to order a new module. It come with newer software version 3.3.
Not sure whether this had been posted before, I find this article more layman friendly:
http://www.bmwtech.ru/pdf/e46/ST034/4 Central Body Electronics Internet.pdf
Just to share.
M Speed USJ : 3/1/12
Power steering pump (LuK LF-20)
Power steering fluid
Labour
RM1350.00
Almost 4K in 2 weeks time... sakit....
Just to share.
Very good document indeed, thanks for sharing!
Don't know why it 'kong' so easily, I faced the same problem when I was taking cornering, nearly lost control. Replace pump from chop shop cost RM750.
