E46 parts & maintenance
318i Gear Box Oil Change Sept 2011 :
1) ZF 5 oil rm42/ltr= 294
2) Filters = 90
3) Gasket = 140
4) Labour = 100
Total = RM 582.00
Service my ride yesterday. Damage as below:
Engine Oil Change : RM 250
1. 4 Litre Engine Oil (Fully Synthetic)
2. Oil Filter
3. Labour
Coil Change : RM 150
1. Ignition Coil
2. Labour
3. Spark Plug
Total : RM400
Done at MSpeed
Did my Alignment at Perellie Subang Glenmarie near Porche and Naza....RM 75 trusted alignment center....no hanky panky no camber adjust if not needed as other shop that always need to adjust camber....this shop also do alignment for BMW auto bavaria Glenmarie, Audi, Porche, Peugot and Ferrari... heard Agong car also they did the alignment.....
hi beemer..im the new member here..what is the best model i can buy for 3 series edition from 2004to 2008? please advice
hairi..ur in the wrong thread..please introduce urself in newbie section..and this thread is for maintenance only..please go to other discussion thread..
Dear Sir,
Please change the Auto Oil & Filter! Once changed, car is faster and smoother and Gearbox will last longer! Auto Bavaria does not recommend change because once you used until breakdown they ask you to buy new Gearbox!
Service my babe yesterday at SAS Auto Putrajaya:
1. lower control arm (right) = RM480
2. lower awm bushing (1 set) = RM280
3. brake pad (front) = RM120
labour = RM116
Total = 996 (wallet bocor already,dang!)
also done some service to my wifey savy, cost me RM1150 to change coil and magnetic speed sensor. the price was so damn expensive due to just a proton car with renault engine. dont recomand others to have savvy!
*i got all the item for my BMW my self, found out a bit cheap to do this way. last time got a quotation from workshop in sunway to change both lower arm for RM1200. doing this way can save me around RM190 (both lower arm + labour = RM960+RM50=RM1010 only)*:top::top:
labour = RM116
Bro don't mind to share what's brand of your item 1 & 2. For me i feel a bit high the price on this two item. Thanks
item 1 = trw
item 2 = lemforder
is it high? i got this from spare part shop in banggi. i do think its cheap since ive been quoted before for the lower control arm for about RM600 a piece.
wow that is sure cheaper! tought min was cheaper...mind to pm me where i can get the item with this price??n what brand??
Already pm you pls check it.
cheers...
Hi,
The paint of the plastic casing and compartment around the handbreak is peeling off.
Can it be reconditioned? any know supplier for this decorative work?
Any mech or supplier that can help if to change a new set?
Thanks
Recently parts changed
1) The Rear axle Rubber Mounting rear 33 17 6 751 808 x 1pc = RM67
2) The Rear axle Rubber Mounting front 33 17 6 770 788 x 2pcs =RM66
Parts await to change
3) The Rear axle support/wheel suspension Ball joint 33 32 6 775 551 x 2pcs = RM170
