E46 parts & maintenance
Service at Turbo Power, Kuchai Lama:
oil filter - RM38
gearbox filter - RM75
gearbox gasket - RM110
rear brake pad - RM150
lower arm bush - RM190
cylinder water cover - RM60
engine oil Revenol - RM290
atf Revenol - RM420
coolant - RM40
labor - RM240
Any comments?
Yikes
Initially I thought I wanted to change my front brake discs and pads only. Turns out I got a whole lot more. All done at Bomin Auto.
Boge Absorber Front (L/R) $640.00
Damper (L/R) $70.00
Absorber mount $240.00
Brake disc Front (Original) $560.00
Brake disc Rear (Febi) $210.00
Brake pad Front (Original) $260.00
Brake pad Rear (TRW) $125.00
Brake sensor (F/R) $90.00
Front control arm bush (LEMFÖRDER) $300.00
Radiator cap $55.00
Door clip (4 pcs) $20.00
Labour $300.00
Total damage: RM2870.00
:102::102::102:
Oil change:
Penzoill Full Synthetic Platinum 5W-40 4L x 2 = RM268
Oil filter hengst = RM40
Belt Change:
Belt drive : Optibelt RM40
Aircond compressor belt : Optibelt RM20
Labour charge: RM60
Belts were bought at Bomin Auto Jln Ipoh. Work done at my regular mech Elegance Autoimage Jln 222 PJ
One of the pulleys is making a slight noise that will be my next agenda ... The hydraulic tensioner is still working fine.
here are the cost for my balik KL repair. Done at ZF Auto Gurney, Penang:
radiator tank = RM580
termostat = RM100
front wheel bearing (L) = RM245
tie rod = RM160
skirt clip = RM40
5w-40 Sheel oil = RM200
workmanship = RM140
TOTAL: RM 1465.00:nurse:
hi guys if im looking at a e46 328i 150k mileage . what do you think i should look out for before buying this car ??
Bro, just bring it to any Beemer workshop, get it check with diagnostic laptop, get the mech to check the engine bay & under-carriage too. For my case, I brought it to a workshop at Tmn Industrial SJ. They even check the battery condition & told me which parts worn out.
The workshop was recommended by my regular mech. Guess what, I got it FOC when I mentionned he was recommended by my regular mech...
BTW, r u buying 4 doors or Coupe?
SMG Gearbox Oil 5 liter - RM600
Pentosin Hydraulic Fluid - RM55
For those who plan to change ur gearbox oil, i'm selling half the oil. SMG gearbox needs roughly about 2.0 liters only .. so theres about more than half remaining in the bottle. can split 50-50. Half price.
Same goes to Pentosin Hydraulic fluid. Selling at half price :)
Do PM me .. thanks.
Bro can share which mech you go to? P.s: I think we stay at the same building. Tiap-tiap pagi sure admire your car as I go out :)
Bro, what a small world :burnout: I'm staying @ Dutamas, but only for another 10 days, i'm moving back to Sabah, with my E46 :cool:
I dont hv his number, but u can contact my regular mech (i used to send my Ford Focus to him for servicing/repair). The beemer workshop is on the same row as my mech's workshop. Add is:
43 Jln TS 6/1, Taman Ind Subang Jaya, SJ. Look for Murali (012-3966675). It is not far from The Summit. Tell him that E46 Coupe Orange (or Ford Focus blue-white) owner gave u the contact. This area is full of car workshops, u can drive around to see some nicely modded toys (cars) :rock:
Awesome! Thanks for sharing! I think the workshop you're talking about is MSpeed kot. :D
Lucky e46 going across the south china sea :D Happy moving!
hmm~ here is my e46 services at ///M ONE skudai johor. going to penang jalan-jalan ...makan angin~~
castrol edge sw.cf 4.litre 210 x2 420
set oil filter element bmw org 60 1 60
bmw coolant 1500ml anti-freeze 55 1 55
wue rapio windscreen cleaner 10 1 10
mos2 engine treatment 300ml 68 1 68
normal service 65 1 65
complete change oil,filter,coolant
& service reset plus clear adaptation funtion.
bosch spark plug-high power 46 x6 276
labour charge for spark plug 35 1 35
control arm bush 190 x2 380
labour charge for control arm bush 85 1 85
oil filter housing gasket 165 1 165
air-cond micro filter e 46 170 1 170
pwr strg presure hose 185 1 185
p/strg tank 135 1 135
power steering oil 38 1 38
clip 8 x4 32
labour charge for power steering 230 1 230
brake oil 85 x2 170
brake pad front G(textar) 265 1 265
brake pad rear 248 1 248
brake pad sensor frt 65 1set 65
brake pad rr 48 1 48
labour charge for brake system 160 160
tayar mechilin ps 3 1050 1 1050
baterreis i guees. parts amaron din 74 580 1 580
SUB TOTAL 4995
So~ thankyou sir pls paid 4995 before going to jalan-jalan.~~~
clip 8 x4 32
brake oil 85 x2 170
SUB TOTAL 4995
You could save more and have more makan angin in Penang:smokin:
That service bill, you can sleep in the car in Penang no need to go to hotel hehehehehe
This workshop is really good in marking up the parts price,some like 100% frm the price at bavarian auto
you can consider buying part from Eng Soon Singapore since you stay in JB, if you don't mind to go across the causeway. My mechanic in Permas Jaya allow me to buy part from Singapore and he charge the labour only.
Actually with higher SG currency, 7% GST, cost & time to get the parts sometimes is not worth. BMW parts price in JB is now more reasonable compare to last time. Some more if anything happend can still fuck off the workshop coz its not our parts. By the way which workshop in Permas??
To be exact.
Ah hua,
We care Auto
31, Jalan Permas 4/4,
Bandar Baru Permas Jaya.
016-7711669
Not all the parts are a lot cheaper. However sometime it is still a lot different betw original and aftermarket. Take the windows lifter as an example, price quite a lot different. I found this from Eng Soon. So the mechanic in Malaysia may use the aftermarket one but charge original one. I am not 100% fancy to the original BMW one as long as the aftermarket one is from a trusted brand name and a lot cheaper.
MyBimmer;675260 said:
To be exact.
Ah hua,
We care Auto
016-7711669
OIC. Of course is much diff compare ori to OEM. I was comparing the same items bet M'sia & SG. Also if the items is faulty how to verify? Pauline wont except the excuses. Even if warranty u have to dismantle and get back the item. I kena many times redy and even f... off Eng Soon 1 time. Its not bout money but more on good will, fair dealing, integrity and our hard earn money to buy and maintain BMW
I believe if you bring the parts the labour is higher. So it will back to square one. Even if its lil bit higher by workshop still he holds the responsibility. I'm talking from my experience. By the way send my regard ah wah. I still remember how much he charge me last time for simple job and also the deal he made for my friend's accident car.:smokin:
Hi Guys,
Im searching for a 2nd hand 325i from used car dealers.
I would like to bring a mechanic to assess the car.
1) Can anyone recommend a good mechanic near jln kuching / kepong.
2) Besides test drive and visual inspection, will an used car dealer allow to send the machine to workshop for more detailed assessment.
Pls pls pls help.
Thanks
